Seeking easy to understand science facts behind simple experiments
The discussion revolves around the scientific principles behind simple preschool science experiments, focusing on phenomena such as bubbles in soda, soap bubbles, and buoyancy in water. Participants seek to clarify the underlying concepts for educational purposes.
  • Homework-related
  • One participant inquires about the cause of bubbles forming around raisins in soda and whether outside air pressure is the only factor involved.
  • Another participant suggests that the pressure of the gas inside the bubbles is greater than that of the air, leading to their bursting, and explains the role of pressurized CO2 in soda.
  • Questions are raised about the role of surface tension in soap bubbles and the process that occurs when they pop, with a description of how gravity affects the distribution of liquid in the bubble.
  • A later reply introduces the concept of interference fringes in soap bubbles, explaining how varying thickness affects the colors observed.
  • Further inquiries are made regarding the scientific explanation for the behavior of toothpicks and pepper in water when dish soap is introduced.
  • Another participant questions the buoyancy of oranges, specifically why a peeled orange sinks while the whole orange and its peel float, pondering the role of air trapped in the peel versus density differences.
  • Participants express appreciation for the educational focus of the thread and the importance of fostering scientific thinking in children.
  • Suggestions for resources, such as a book on science activities for children, are shared to aid in the educational efforts.
Participants generally agree on the importance of understanding scientific principles for educational activities, but multiple competing views and questions remain regarding the specific mechanisms behind the discussed phenomena.
Some concepts, such as density and the behavior of bubbles, are discussed with varying levels of detail and assumptions that may not be fully resolved in the conversation.
Educators, parents, and individuals interested in early childhood science education may find this discussion beneficial for developing engaging science activities.
Blouella
Hi. I am writing preschool science activities and would like to verify what the scientific principles behind them are.
First example: when you put raisins in clear soda pop, exactly what causes the bubbles around the raisins to pop when they reach the top? Is it only the outside air pressure?
Second example: when you blow through a film of soap to create bubbles, is it surface tension that holds the soap together around the air? And what exactly happens when they pop?
Thank you.
Hi Blouella, welcome to Physics Forums!
Yes, this is correct. The pressure of the gas inside the bubble is greater than that of the air so they burst. Soda is bubbled by dissolving highly pressurized CO2 gas in it. The pressure is so high that some of the gas comes out of solution following the bottling (it lives in the little "air" space between the top of the liquid and the bottle cap); it escapes with a "whoosh" upon opening the bottle.
Thank you.
You are right again, it is surface tension. If you look carefully at a bubble, you will see that fluid tends to distribute from the top of the bubble to the bottom over the space of a few seconds, due to the pull of gravity. Sometimes you even see the start of a drip formi9ng at the bottom as liquid collects there. Eventually the top becomes so thin that it can't support itself and the bubble comes apart--it pops.
Here's another interesting bubble phenomenon. The thickness of the soap film can get very small--comparable to the wavelength of light (of order 1/2 micron, or 5x10^(-7) meters). When this happens you see interference fringes, which look like wavy patterns of color. If the film becomes half the thickness of green light, say, or an integer number times that thickness, then green light reflecting off of the inner and outer surfaces of the film add in phase while other colors reflect out of phase and are suppressed. You see a green reflection. At a different thickness, a different color is favored. So as the bubble thins at top and thickens at bottom, you'll see a progression of color changes. They look wavy and multicolored both because illumination in a typical room is kind of random and because the film thickness is not uniform.
Thank you Marcus! This is exactly the information I needed.
Here are two more activities that I would like to verify:
What happens, scientifically, when you float two toothpicks in water then dip a straw with dish soap into the water? Or similarly with pepper in water and dish soap?
Also, an orange floats in (enough) water. So does the peel. But the peeled orange sinks. Is this due to air trapped in the peel making it lighter? Or is it a more complicated situation with the orange or the peel or the peeled orange being more or less dense than the water? And if so, what does "density" actually mean?
I hope these questions are not too basic, but these are the things I need to know.
Thanks again.
Welcome from me as well.
I have nothing to contribute in the context of this thread, but I want to express how pleased I am that someone is introducing the youngsters to science in a manner appropriate for their age group. PF is all about education, and you will be a pleasing addition.
Thank you, Danger!
I am writing preschool science books that help children learn the science behind the activity, as you mentioned. It will also encourage them to think and guess (predict) instead of just being "handed" the answers. I believe this develops a measure of common sense thinking, which is sometimes in short supply! ;-)
An excellent book than you might want to glance at is James Lewis' Learn While you Scrub: Science in the Tub. It's exactly as you would expect from the title.
I'm late with this but thank you Vanadium. I will definitely start hunting it down.
  • · Replies 25 ·
  • · Replies 22 ·
  • · Replies 20 ·
  • · Replies 42 ·
