Thread Closed
divergence and curl of vector field defined by \vec A = f(r)vec r
Share Thread Thread Tools
Oct11-08, 02:44 PM   #1
A vector field is defined by A=f(r)r
a) show that f(r) = constant/r^3 if [tex]\nabla[/tex]. A = 0
b) show that [tex]\nabla[/tex]. A is always equal to zero
2. Relevant equations
divergence and curl relations
3. The attempt at a solution
I tried using spherical co-ordinates to solve this. But I am not sure if i am totally right.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Hong Kong launches first electric taxis
>> Morocco to harness the wind in energy hunt
>> Galaxy's Ring of Fire
Oct11-08, 07:05 PM   #2
G01
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
I would also use spherical coordinates on this problem.
I cannot say if you are right since I haven't seen any of your work. I'll need to see some work if you want more specific advice.
Oct11-08, 08:33 PM   #3
Recognitions:
Quote by FourierX View Post
Certainly parts (a) and (b) can not be consistent as you have written them... i suppose part (b) should be a curl not a divergence?
Oct11-08, 10:58 PM   #4
here is what i've done and where i got stuck:
[tex]\nabla[/tex]A = [tex]\frac{1}{r^{2}}[/tex] [tex]\frac{\partial}{\partial r} (r^{2}f(r))[/tex]
on simplifying this i got:
f(r) = [tex]\frac{-1}{2} r f'(r)[/tex]
then i integrated with a hope to get an expression for f(r) but did not end up with what i needed i.e. f(r) = constant/ r^{3}
Oct12-08, 09:08 PM   #5
Recognitions:
Well the way you interpreted it, you have [tex]\mathbf{A}=f(r)\hat{r}[/tex], but the way the question is stated it is [tex]\mathbf{A}=f(r)\mathbf{r}=[/tex], or [tex]\mathbf{A}=f(r)r\hat{r}[/tex]. This extra factor of r should give the answer required.
Thread Closed
Tags
curl, divergence, vector
Thread Tools
Similar Threads for: divergence and curl of vector field defined by \vec A = f(r)vec r
Thread Forum Replies
Curl about an elipse. Line integral of vector field Calculus & Beyond Homework 3
If the divergence of a vector field is zero... Calculus & Beyond Homework 5
How to interpret physically the divergence of vector field? General Physics 8
Divergence of a Radial Vector Field Calculus 2
A question about path independence and curl of a vector field Calculus 4
