Dipole moment electric potential
The discussion focuses on calculating the electric potential from a dipole moment of 2.6 nCm at a distance of 18 cm. For part (a), the user struggles with the equation for the electric potential at an angle of 42 degrees, initially using an incorrect approach and arriving at values of 1.08 kV and 0.971 kV, which are deemed incorrect. The user seeks clarification on the correct formula for the dipole moment and how to incorporate the angle into the calculations. In part (b), the user notes that the perpendicular bisector is at 90 degrees, leading to a potential of zero when multiplied by cos(90 degrees). The discussion highlights the challenges in applying the correct equations for electric dipoles and the need for further assistance.
jelliDollFace
what is the potential 18 cm from a dipole moment 2.6nCm at
a) 42 deg to axis
b) on the perpendicular bisector
note: dipole separation << 18cm
electric dipole moment, p = qd where q is charge, d is distance
electric potential for point charge, V = kq/r where k is 9*10^9 and r is distance
a) 42 degrees
i think my eq may be wrong, but...
p =qd sin (theta) where theta = 42deg
so q = p/dsin(theta)
so V = [k(p/dsin(theta)]/r
so using sin(42) i got V = 1.08 kV and using cos(42) i got V = 0.971 kV --> both incorrect
i'm guessing my eq for electric dipole moment is wrong, i was thinking along the lines of the torque eq, rFsin(theta)
b) not attempted yet, but what is the perpendicular bisector? any tips much appreciated
how do i factor in the angle into the dipole moment for part a?
anyone, its been 4 days, please help
for part a, i just mulitplied the V you get in the beginning (on the dipole axis) by cos(angle given).
for b, the perpendicular bisector is 90 degrees from the, and if u multiply V by cos(90 deg) you get zero.
at least that's how i solved it, and my answers came out right.
