The sum of three numbers is 4.
  • Thread starter Thread starter Pumblechook
    Numbers Sum
The problem involves three numbers whose sum is 4, with additional conditions regarding the sum of their squares and cubes. Participants are exploring how to determine the sum of their fourth powers based on these relationships.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss the relationships between the sums of powers and consider various methods, including polynomial approaches and the use of equations. Questions arise about the interpretation of the variables involved and the implications of potential negative numbers.
There is an ongoing exploration of different methods to approach the problem, with some participants suggesting polynomial relationships and others questioning the assumptions made about the variables. Guidance has been offered regarding the use of sums of powers and polynomial coefficients.
Some participants initially misinterpreted the number of variables involved, leading to clarifications about the correct setup of the equations. The discussion reflects a mix of interpretations and approaches without reaching a consensus on a specific method.
Pumblechook
The sum of three numbers is 4, the sum of their squares is 10 and the sum of their cubes is 22. What is the sum of their fourth powers?
If the unknown numbers are a,b,c,d and
Your data can now be written as
a+b+c+d=4
a2+b2+c2+d2=10
a3+b3+c3+d3=22
how do you think you would have to get a4+b4+c4+d4?
a+b+c+d=4
a2+b2+c2+d2=10
a3+b3+c3+d3=22
Where did the d value come from?
Also, I see the pattern, but are you sure this works?
This sounds more like a riddle to me, so you could just think about it very carefully ;-). Might I suggest looking at negative numbers as possibilities? I didn't actually solve the problem, but that seems like it might work.
my bad, I read it as the sum of 4 numbers...it should be
[tex]a+b+c=4[/tex]
[tex]a^2+b^2+c^2=10[/tex]
[tex]a^3+b^3+c^3=22[/tex]
If one felt inclined, one could attempt to solve these 3 equations, with 3 unknowns and then calculate [itex]a^4+b^4+c^4[/itex], or consider a,b,c to be the roots of a cubic polynomial and then use the relations of the roots to the coefficients and go from there with some helpful sums.
The cubic polynomial method suggested by rock.freak667
is indeed the way to go.
We define Sn to be the sum of the n-th powers:
a + b + c = S1,
a^2 + b^2 + c^2 = S2,
a^3 + b^3 + c^3 = S3,
We want to express
S4 = a^4 + b^4 + c^4
in terms of S1, S2 and S3.
Consider the polynomial
P(x) = (1 + ax)(1 + bx)(1 + cx)
If we take the Logarithm of this, we get:
Log[P(x)] = Log(1+ax) + Log(1+bx) + Log(1+cx)
(Log denotes natural logarithm)
Next, we use the series expansion:
Log(1+y) = y - y^2/2 + y^3/3 - y^4/4 + ...
to expand Log[P(x)]. The coefficient of x^n then becomes proportional to Sn:
Log[P(x)] = S1 x - S2/2 x^2 + S3/3 x^3 - S4/4 x^4 + ...
Now take the exponential function of both sides. The left hand sided then becomes:
exp{Log[P(x)]} = P(x)
On the right hand side we expand the exponential function using the series expansion
exp(y) = 1 + y + y^2/2 + y^3/6 + y^4/24 + ...
So, we have:
P(x) =
exp(S1 x - S2/2 x^2 + S3/3 x^3 - S4/4 x^4 + ...) =
1 + S1 x + (S1^2 - S2)/2 x^2 + (S1^3/6 - S1 S2/2 + S3/3) x^3 +
(S1^4/24 - S1^2 S2/4 + S1 S3/3 + S2^2/8 - S4/4 ) x^4 + ...
But since P(x) is a third degree polynomial, the coefficients of x^n for n >3 must be zero. If you equate the coefficient of x^4 to zero, you get:
S1^4/24 - S1^2 S2/4 + S1 S3/3 + S2^2/8 - S4/4 = 0 ------>
S4 = S1^4/6 - S1^2 S2 +4/3 S1 S3 + S2^2/2
If you substitute the numbers for S1, S2 and S3, you get S4 = 50.
If you are curious about the numbers a, b, and c, you can use that we now have the polynomial P(x) in expanded form:
P(x) = 1 + S1 x + (S1^2 - S2)/2 x^2 + (S1^3/6 - S1 S2/2 + S3/3) x^3 =
1 + 4 x + 3 x^2 - 2 x^3
Since P(x) was defined as
P(x) = (1 + ax) (1 + bx)(1 + cx),
the zeroes of P(x) are -1/a, -1/b, -1/c
Solving the polynomial then gives
2, 1 + sqrt(2) and 1 - sqrt(2)
for the numbers.
  • · Replies 32 ·
