Heat conduction in bars: varying the boundary condition. Harmonics problem
The discussion revolves around a heat conduction problem involving the heat equation with specific boundary conditions and an initial condition. The subject area includes partial differential equations and separation of variables, focusing on odd harmonics in the solution.
  • Exploratory, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the separation of variables method and the resulting ordinary differential equations (ODEs) for both spatial and temporal components. There are inquiries about the general solutions for these ODEs and the implications of different cases for the separation constant. Some participants express confusion regarding boundary conditions and the derivation process.
The discussion is ongoing, with participants providing insights into the separation of variables and eigenvalue selection. Some guidance has been offered regarding the nature of the eigenvalues and the form of the solutions, but there remains a lack of consensus on specific steps and interpretations, particularly concerning boundary conditions and the spatial ODE.
Participants are navigating the complexities of boundary conditions, particularly Dirichlet conditions, and how they affect the eigenvalue problem. There is also mention of the initial temperature distribution and its role in determining coefficients in the series solution.
Benzoate
A problem with odd harmonics only. Show that the solution of the heat equation du/dt=c2*(d2u)/(dx2), subject to boundary conditions u(0,t)=0 and ux(L,t)=0, and the initial condition u(x,0)=f(x) , is
u(x,t)= [tex]\sum[/tex] Bnsin[([tex]\pi[/tex]/2L)(2n+1)x]e-((c*[tex]\pi[/tex]/2L)*(2n+1))^2
where n extends from 0 to [tex]\infty[/tex]
Bn=2/L[tex]\int[/tex] f(x) sin[([tex]\pi[/tex]/2L)*(2n+1)x]dx
where the limits extend from 0 to L
u(x,t)=X(x)T(t)
u(x,0)=f(x)
u2(x,t)=0
T'-kc2T=0
x''-kx=0
x'(0)=0
x'(L)=0
u2(0,t)=0
if u(0,t)=0 then u2(0,t)=0
u2(0,t)=0= u2(L,t)
not sure how to finish this derivation.
Benzoate said:
u(x,t)=X(x)T(t)
u(x,0)=f(x)
T'-kc2T=0
x''-kx=0
This part is correct. What does that make the general solution for T(t) and X(t) and hence u(x,t)? Remember, you will need to examine 3 different cases: (1)k=0, (2)k<0 and (3)k>0.
u2(x,t)=0
Huh? What is this supposed to mean?
x'(0)=0
x'(L)=0
u2(0,t)=0
u2(0,t)=0= u2(L,t)
Where are you getting these boundary conditions? They are not equal to the conditions given in the question.
3 cases : you mean when
case 1: lambda =alpha^2 ==> X-alpha^2*X
X''-alphaX=0
r^2-alpha^2=0
(r-alpha)(r+alpha)=0 ==> r= +-alpha
X=c1e^alpha*x + c2e^alphae^-alpha
X'(0)=0 ==> c1*alpha-c2*alpha
X'(L)=alpha(e^alpha*L - e^(-alpha*L))c1=0 ==> c1=0
case 2 lamda =0
r=0
X=c1*x+c2
X'(0)=0 ==> c1=0
X'(L) =0 ==>0=0
X(x)=c2case 3
lambda = alpha^2 >0
r^2+alpha^2 =0 ==> r=+- alpha*i
X1=cos(alpha*x) X2=sin(alpha*x)
X=X1+X2= cos(alpha*x)+sin(alpha*x)
Ignore all the functions with u2. Those are all mistakes. ; I was trying to say that if u(0,t)=0 then u(0,t)=0==> ux(0,t)=0
Therefore, ux(0,t)=0= ux(L,t)
1. After SOV, you'll get 2 ODEs. One for spatial the other for time, then you select proper eigenvalue such that the PDE has nontrivial and physically possible solution considering the given BCs. In the case of
[tex]\dfrac {T'}{T}= k \dfrac {X''}{X}=- \lambda[/tex] with Dirichlet boundary conditions, the possible eigenvalue is [tex]\lambda >0[/tex] (easy to find out by plugging the BCs in).
2. Solve the spatial ODE, determine the coefficients and eigenvalues to satisfy the BCs.
3. Solve the T, and plug the eigenvalue into the T.
4. Write the u(x,t) in series form by applying the principle of superposition.
3. Apply initial condition to u(x,t) by setting t=0 such that u(x,0)=f(x).
4. determine the Fourier coeffs.
Should I let X= c1 cos ([tex]\mu[/tex] x) + c2 sin ([tex]\mu[/tex]x)
and k=-[tex]\mu[/tex]2 ; should I write T/T' in terms of c and k ?
What is the spatial ODE?
Not sure how to determined the eigenvalues
Let's say you have a 1D heat diffusion problem
[tex] \dfrac{\partial u}{\partial t} = k \dfrac{\partial ^2u}{\partial x^2}[/tex]
where 0<=x<=L, and with Dirichlet boundary conditions
[tex] u(0,t)=u(L,t)=0[/tex]
and initial temperature distribution
[tex] u(x,0)=f(x)[/tex]
To SOV set:
[tex] u(x,t)=\phi(x)T(t)[/tex]
We could set the separation constant [tex]-\lambda[/tex]
you get
[tex] \dfrac{\phi^''}{\phi}=\dfrac{1}{k} \dfrac {T^'}{t}=- \lambda[/tex]
you end up having 2 ODEs
[tex] \phi^{''}+\lambda \phi = 0[/tex]
and
[tex] T^{'}+\lambda kt = 0[/tex]
[tex]\phi^{''}+\lambda \phi = 0[/tex] is the spatial ODE. it's the simplest form of Sturm-Liouville Eigenvalue problem.
we can prove that the only way to get nontrivial solution is when [tex]\lambda>0[/tex], and the general solution to the spatial problem is
[tex] \phi(x)=c1 sin(\sqrt{\lambda}x)+c2 cos(\sqrt{\lambda}x)[/tex]
To satisfy the Dirichlet BC, it requires c2=0 and
[tex] \lambda=(\dfrac{n \pi}{L})^2[/tex]
now you have
[tex] \phi(x)= cn \sin(\dfrac{n\pi x}{L})[/tex]
the solution to T is
[tex] T(t)=Bne^{-k \lambda t}[/tex]
Plug lambda into T(t) and apply principle of superposition you have
[tex] u(x,t)=\sum _{n=1} ^{\infty} A_{n}sin \dfrac{n \pi x}{L}e^{-k(n \pi/L)^2t}[/tex]
Now you need to make u(x,t) satisfy the initial condition and determine the A_{n}. Let us know if you have further problems.
