Unraveling the Complex Derivative of Arctan(z)
The discussion revolves around the complex derivative of the arctangent function, specifically arctan(z), and its relationship to the complex argument function, Arg(z). Participants explore the complexities of differentiating these functions within the context of complex analysis, addressing issues related to computational software outputs and the nature of differentiability in complex variables.
  • Some participants propose that the derivative of arctan(z) is 1/(1+z^2), while others express confusion regarding this claim based on outputs from computer algebra systems (CAS).
  • One participant suggests that the derivative of Arg(z) should equal 1/(z^2+1) because of its relation to arctan(z), but this is challenged by another who states that Arg(z) is not complex-differentiable.
  • There is a discussion about the differentiability of Arg(A+C*x) where A and B are complex constants and x is a real number, with some suggesting that Arg is differentiable as a function on the plane but not as a complex function.
  • Participants question why the derivative of Arg appears to have an imaginary part, leading to speculation about the nature of the inputs provided to the CAS.
  • One participant notes that Mathematica's behavior changes based on whether a variable is treated as a numerical value or as a formal symbol, affecting the output of the derivative.
  • Another participant suggests using assumptions or transformations to obtain the correct results when working with Arg in Mathematica.
Participants express differing views on the differentiability of Arg(z) and the validity of the derivative of arctan(z) as presented. There is no consensus on the correct interpretation of the derivative outputs from the CAS, and multiple competing views remain regarding the relationship between Arg and arctan.
Limitations include the dependence on the definitions of differentiability in complex analysis and the behavior of computational tools like Mathematica, which may yield different results based on the context of the variables used.
daudaudaudau
If z is a complex number, isn't the derivative of arctan(z) just 1/(1+z^2) ? That's what I would think, but my CAS does not agree with me.
The derivative of arctan(z) is 1/(1+ z^2)+ C no matter what number field z is in. What does your CAS say?
I meant to write: Isn't the derivative of the complex argument of z, Arg(z) equal to 1/(z^2+1) beacuse this is the derivative of arctan(z) ?
I don't see your line of reasoning.
Anyways, the facts of the situation are that Arg(z) isn't complex-differentiable. (Try computing it directly) You have a huge clue that something's wrong: Arg(z) is a strictly real-valued function, yet your alledged derivative can take complex values.
Yes, that made no sense, sorry. What about if A and B are a complex constants and x is a real number. Then I suppose the derivative of Arg(A+C*x) exists ?
Arg is differentiable as a function on the plane. It's just not differentiable as a complex function.
What about this attached screenshot then? Why does the derivative even have an imaginary part?
My best guess is that you gave a, or maybe x, a numerical value earlier in your session. What does it think
D[Arg[x*(I+1)+1],x]​
and
D[Arg[x*(I+1)+1],x]/.x->a​
simplify to?
I started a new session, and this is what it looks like. D[Arg[...]] makes no sense, but D[ArcTan[...]] looks about right. Isn't Arg using ArcTan ?
Aha, I see what's going on.
Mathematica's documentation says that it only 'evaluates' Arg when it has a numerical result. It's internal thinking about the function changed in the following way:
When you first asked for the derivative, it made a purely formal calculation via the chain rule, probably thinking of it as a 'formal' complex derivative. (Note that mathematica will do the same thing with any formal symbol. Try asking for D[f[x], x] when you haven't defined f)
But when you replaced x with an actual number, you kicked in the programming for Arg, so it happily returned (1+i) times whatever it thinks the derivative of Arg should be. (I can't explain the extra factor of -1/2, though))
If you want to insist on working with Arg directly, you might be able to get better results in one of the following ways:
. Use assumptions to tell Mathematica that x is a real number.
. Try replacing x in the expression with Abs[x], or maybe Re[x].
Yes, that seems to be the case. Apparently one has to write D[ComplexExpand[Arg[x*(1 + I) + 1], TargetFunctions -> {Re, Im}], x]
to get the "right" result. :)
