Thread Closed
Help with Java Language Filter
Share Thread
Oct13-08, 07:54 PM   #1
I have run into a problem... The language filter we have been using is out of date and it periodically does not work. I was hoping I could get some help on making a new one.
The old one:
Code:
import java.io.File;
import java.io.FileWriter;
import java.io.PrintWriter;
import java.net.SocketAddress;
import java.util.ArrayList;
import java.util.Map;
import java.util.Scanner;
import java.util.StringTokenizer;
import pokeglobal.server.object.Char;
import pokeglobal.server.object.PlayerChar;
 * Filters bad language along with Game Moderator commands
public class Moderator {
	private ArrayList<Filter> CensorList = new ArrayList<Filter>();
	private Map<String, PlayerChar> playerList;
	    * Default Constructor which loads bad language database
	public Moderator()
		loadFilter();
		playerList = ClientHandler.getPlayerList();
	    * Adds a new bad word to the database and restarts the moderating system without a server shutdown.
	    * @param String wordToFilter - badword:goodword , The word to be filtered will be replaced with the good word
	//Allows mods to add a new word to the filter
	void addFilter(String wordToFilter)
		try
			if (!wordToFilter.contains(":")) throw new Exception();
			PrintWriter filterWord = new PrintWriter(new FileWriter(
					"res/badwords.txt"));
			for(int i = 0; i < CensorList.size(); i++)
				filterWord.println(CensorList.get(i).getOriginal() + ":" + CensorList.get(i).getNew());
			filterWord.println(wordToFilter);
			//Close PrintWriters
			filterWord.close();
			//Reload filter list
			loadFilter();
		catch (Exception e)
			System.out.println("Could not add word to filter database");
	    * Reloads the moderating database without restarting the server
	//Reloads the filter list
	void loadFilter()
		try
			CensorList.clear();
			Scanner originalWords = new Scanner(new File("res/badwords.txt"));
			while(originalWords.hasNextLine())
				String s = originalWords.nextLine();
				Filter f = new Filter();
				if(s.indexOf("*") == 0)
					f.set(s.substring(1), true);
				else
					f.set(s, false);
				CensorList.add(f);
			originalWords.close();
		catch (Exception e)
			e.printStackTrace();
	    * Filters words/commands appropriately
	    * @param String messageSent - The message sent by the player
	    * @param PlayerChar username - The player who sent the message
	//Returns the filtered word and executes any mods commands sent by mods
	String filter(String messageSent, PlayerChar username)
		String output = "";
		if(!username.isMod())
			output = removeBad(messageSent);
		else
			boolean playerFound = false;
			if(messageSent.indexOf("/addWord") == 0)
				addFilter(messageSent.substring(8));
				output = username.getName() + " updated the Moderating System";
			else if(messageSent.indexOf("/kick ") == 0)
				for (String key : playerList.keySet())
					if(key.equalsIgnoreCase(messageSent.substring(5).trim()))
						if (!playerList.get(key).isMod()){
							playerFound = true;
							kickPlayer(key);
							username.getMap().sendToAll("CServer: " + messageSent.substring(5).trim() + " was kicked!");
						break;
				if (!playerFound)
					username.getIoSession().write("CServer: " + messageSent.substring(5).trim() + " does not exist!");
			else if(messageSent.indexOf("/kickall") == 0)
					kickPlayer(key);
			else if(messageSent.indexOf("/mute") == 0)
								playerFound = true;
								mutePlayer(key);
								username.getMap().sendToAll("CServer: " + messageSent.substring(5).trim() + " was muted!");
							break;
					if (!playerFound)
			else if(messageSent.indexOf("/silentmute") == 0)
						if(key.equalsIgnoreCase(messageSent.substring(11).trim()))
								playerFound = true;
								silentmutePlayer(key);
							break;
					if (!playerFound)
			else if(messageSent.indexOf("/disable") == 0)
						if(key.equalsIgnoreCase(messageSent.substring(8).trim()))
								playerFound = true;
								disablePlayer(key);
								username.getMap().sendToAll("CServer: " + messageSent.substring(8).trim() + " was disabled!");
							break;
					if (!playerFound)
						username.getIoSession().write("CServer: " + messageSent.substring(8).trim() + " does not exist!");
			else if(messageSent.indexOf("/enable") == 0)
						if(key.equalsIgnoreCase(messageSent.substring(7).trim()))
								playerFound = true;
								enablePlayer(key);
								username.getMap().sendToAll("CServer: " + messageSent.substring(7).trim() + " was freed from all moderator restrictions!");
							break;
					if (!playerFound)
						username.getIoSession().write("CServer: " + messageSent.substring(7).trim() + " does not exist!");
			else if(messageSent.indexOf("/unmute") == 0)
								playerFound = true;
								unmutePlayer(key);
								username.getMap().sendToAll("CServer: " + messageSent.substring(7).trim() + " was unmuted!");
							break;
					if (!playerFound)
			else if(messageSent.indexOf("/freeze") == 0)
							playerFound = true;
							freezePlayer(key);
							username.getMap().sendToAll("CServer: " + messageSent.substring(7).trim() + " was frozen!");
						break;
				if (!playerFound)
			/*else if(messageSent.indexOf("/trade") == 0)
					if(key.equalsIgnoreCase(messageSent.substring(6).trim()))
							playerFound = true;
							PlayerChar player = playerList.get(key);
							player.addTradePokemon(username.getParty()[0]);
							username.removePokemon(username.getParty()[0]);
							username.getMap().sendToAll("CServer: ");
						break;
				if (!playerFound)
			else if(messageSent.indexOf("/unfreeze") == 0)
					if(key.equalsIgnoreCase(messageSent.substring(9).trim()))
							playerFound = true;
							unfreezePlayer(key);
							username.getMap().sendToAll("CServer: " + messageSent.substring(9).trim() + " was unfrozen!");
						break;
				if (!playerFound)
					username.getIoSession().write("CServer: " + messageSent.substring(9).trim() + " does not exist!");
			else if(messageSent.indexOf("/who") == 0)
				int playerCount = 0;
					playerCount = playerCount + 1;
					output = output + key + ", ";
				username.getIoSession().write("C" + playerCount + " Players Online: " + output);
				output = "";
			} else if (messageSent.indexOf("/antilag") == 0) {
				playerList.get(username).getIoSession().close();
			/*else if(messageSent.indexOf("/setsprite") == 0){
				username.getName();
				username.setSprite(messageSent.substring(10));
				username.getMap().sendToAll("CServer: GM changed his sprite and needs to reload.");
			// /pos command gets server to tell your position in chat.
			else if(messageSent.indexOf("/pos") == 0){
					if(key.equalsIgnoreCase(messageSent.substring(4).trim()))
							playerFound = true;
							posPlayer(key, username);
						break;
				if (!playerFound)
					username.getIoSession().write("CServer: " + messageSent.substring(4).trim() + " does not exist!");
			else if(messageSent.indexOf("/teletoplayer") == 0){
					if(key.equalsIgnoreCase(messageSent.substring(13).trim()))
							playerFound = true;
							teleToPlayerPlayer(key, username);
						break;
				if (!playerFound)
			else if(messageSent.indexOf("/getip") == 0){
				for(String key : playerList.keySet()){
					if(key.equalsIgnoreCase(messageSent.substring(13).trim())){
						if(!playerList.get(key).isMod()){
							username.getIoSession().write("CServer: The player " + player.getName() + " ip is " + player.getIoSession().getLocalAddress());
						}else{
							username.getIoSession().write("CServer: You cannot try to get game moderator ip address.");
			else if(messageSent.indexOf("/announce") == 0){
				for (PlayerChar p : playerList.values())
					p.getIoSession().write("C<Server Announcement>: " + messageSent.substring(9).trim());
			else
		return output;
	    * Removes all bad language
	String removeBad(String messageSent)
		String temp = messageSent.trim();
		StringTokenizer st3 = new StringTokenizer(temp);
		String output = "";
		while(st3.hasMoreTokens())
			String check = st3.nextToken();
				if(CensorList.get(i).hasWildCard)
					if(check.toLowerCase().indexOf(CensorList.get(i).getOriginal().toLowerCase()) >= 0)
						check = CensorList.get(i).getNew();
						break;
				else
					if(check.equalsIgnoreCase(CensorList.get(i).getOriginal()))
						break;
			output = output + check + " ";
		return output;
	    * Kicks a player from the server and informs the player they have been kicked
	    * @param String playerName - Player's name
	void kickPlayer(String playerName)
		PlayerChar player = playerList.get(playerName);
		if (player != null && !player.isMod()) {
			try
				player.getIoSession().write("mYou have been kicked from Pokemon Global.");
				Thread.sleep(500);
			catch (Exception e)
			finally
				player.getIoSession().close();
				System.out.println(playerName + " was kicked!");
	    * Mutes a player (disables them from using chat) and informs them they have been muted
	    * @param String playername - Player's name
	void mutePlayer(String playerName)
			try
				player.getIoSession().write("mYou have been muted. You may no longer use the chat functions.");
				player.setMuted(true);
				Thread.sleep(500);
			catch (Exception e)
			finally
				System.out.println(playerName + " was muted!");
	void silentmutePlayer(String playerName)
			try
				Thread.sleep(500);
			catch (Exception e)
	    * Unmutes a player and informs them they have been unmuted
	void unmutePlayer(String playerName)
			try
				player.getIoSession().write("mYou have been unmuted. You may now use the chat functions again.");
				player.setMuted(false);
				Thread.sleep(500);
			catch (Exception e)
			finally
				System.out.println(playerName + " was unmuted!");
	    * Freezes and Mutes a player
	void disablePlayer(String playerName)
			try
				player.setFrozen(true);
				player.getIoSession().write("mYou have been disabled from using Pokemon Global.");
				Thread.sleep(500);
			catch (Exception e)
			finally
				System.out.println(playerName + " was disabled!");
	    * Unfreezes and unmutes a player
	void enablePlayer(String playerName)
			try
				player.setFrozen(false);
				player.getIoSession().write("mYou have been freed from all moderator restrictions.");
				Thread.sleep(500);
			catch (Exception e)
			finally
				System.out.println(playerName + " was enabled!");
	    * Disables player movement
		void freezePlayer(String playerName)
			try
				player.getIoSession().write("mYou have been frozen. You may no longer move. A moderator may require your attention.");
				Thread.sleep(500);
			catch (Exception e)
			finally
				System.out.println(playerName + " was frozen!");
		    * Re-enables player's movement
	void unfreezePlayer(String playerName)
			try
				player.getIoSession().write("mYou have been unfrozen. You may move again.");
				Thread.sleep(500);
			catch (Exception e)
			finally
				System.out.println(playerName + " was unfrozen!");
	void posPlayer(String playerName, PlayerChar username)
			try
				player.getName() +
				"'s current map position is: " +
				player.getMapX() +
				player.getMapY() +
				player.getName() +
				"'s current map co-ord's are: " +
				player.getX() +
				player.getY() +
				Thread.sleep(500);
			catch (Exception e)
			finally
				System.out.println("Found the position for " + playerName);
	void teleToPlayerPlayer(String playerName, PlayerChar username)
			try
				username.setMap(player.getMap());
				username.setX(player.getX());
				username.setY(player.getY());
				username.getIoSession().write("C" + "You have teleported to player" + playerName);
				Thread.sleep(500);
			catch (Exception e)
			finally
class Filter
	private String f;
	boolean hasWildCard;
	void set(String o1, boolean wild)
		f = o1;
		hasWildCard = wild;
	String getOriginal()
		return f.substring(0, f.indexOf(':'));
	String getNew()
		return f.substring(f.indexOf(':') + 1);
The "/res/badwords.txt" is:
Badword:GoodWord
Badword is any bad word that you want filtered out
Goodword is what you are replacing it with (like !@#$)
Now this system does work sometimes, but recently the server was updated and this system has fallen apart. If anyone has any concept ideas or anything please let me know. Thank you.
PhysOrg.com science news on PhysOrg.com
>> A robot that runs like a cat (w/ Video)
>> Global cooling as significant as global warming, research shows
>> 'Chase and run' cell movement mechanism explains process of metastasis
Oct26-08, 12:16 PM   #2
Do you get paid for fixing this? We don't.
We're here to help, so you need to help us to help you.
Most people would look at a post, and give an answer in a matter of a minute. If it takes more time than that, they move on. Guess why there is not a single answer since your post ten days ago.
Here are some suggestions:
1. Be precise about your problem.
...it periodically does not work.
...this system has fallen apart.
does not tell us much unless you indicate what makes you think it does not work, error messages, etc.
2. Extract the part of the code that you think is causing the problem.
If you think people have nothing better to do than to study your precisely 650 lines of code to look for your problem, think twice. This is your responsibility to help people to help you.
If you are not a programmer, or if you did not write the programme, hire one.
Thread Closed
Tags
code, filter, java, language, programming
Similar Threads for: Help with Java Language Filter
Thread Forum Replies
Why is the bandwidth of the RF filter is wider compared to that of an IF Filter? General Engineering 4
FIR Filter Electrical Engineering 2
Using the language of mathematics, state and prove that mathematics is a language General Math 40
Series RLC filter (trap filter) Introductory Physics Homework 7
