Complex Variable-definite integral
  • Thread starter Thread starter Microzero
    Complex Integral
The discussion revolves around evaluating a definite integral involving complex variables, specifically the function f(k) defined by an integral with a pole at z = iε. The participants explore the behavior of this function for different values of k, particularly focusing on the cases where k is greater than or less than zero.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the evaluation of the integral using contour integration, considering the placement of the contour in relation to the poles for different k values. There is an emphasis on the need to take the limit as ε approaches zero and the implications of this limit on the integral's value.
The discussion is ongoing, with participants attempting to clarify the conditions under which the integral evaluates to 1 or 0. Some have suggested that the limit of ε is crucial for resolving the integral's value, while others are exploring the implications of different contours for the two cases of k.
There is a noted assumption that ε is greater than zero, but participants are questioning how this impacts the evaluation of the integral as ε approaches zero.
Microzero
Complex Variable---definite integral
Show that
f(k) = [tex]\frac{1}{2i\pi}[/tex] [tex]\int^{\infty}_{-\infty}[/tex] [tex]\frac{e^{ikx}}{x-i\epsilon}dx[/tex] =
1, if k>0
0, if k<0
where [tex]\epsilon[/tex] > 0
The attempt at a solution
Consider : [tex]\oint[/tex] [tex]\frac{e^{ikz}}{z-i\epsilon}dz[/tex]
the residule is : e^(-k[tex]\epsilon[/tex])
so [tex]\int^{\infty}_{-\infty}[/tex] [tex]\frac{e^{ikx}}{x-i\epsilon}dx[/tex]
= [tex]{2i\pi}[/tex] e^(-k[tex]\epsilon[/tex])
f(k) = [tex]\frac{1}{2i\pi}[/tex] [tex]\int^{\infty}_{-\infty}[/tex] [tex]\frac{e^{ikx}}{x-i\epsilon}dx[/tex] = e^(-k[tex]\epsilon[/tex])
I can't prove it equal to 0 or 1 and the required condition.
I hope you mean e^(-k*epsilon). You are leaving out some steps. If you are starting with k>0 you first need to figure out whether you will close the contour in the upper or lower half plane. Since you have exp(ikx) and you want that to be small for x far out on the arc you are using to close the contour, you pick the upper half plane since Im(x)>0 there. Yes, then you pick up the pole at i*epsilon. You are now leaving out the final step of taking epsilon->0. If k<0 then you close in the lower half plane. Now what?
So...the above result i obtained means that I just consider k>0, right?
then I should find the residule for two case:
k>0 and k<0
then f(k) is equal to the sum of residules
correct?
You already found the residue of the pole for the k>0 case (though you didn't justify it very well). What does happen if k<0? NO. You don't ADD them. They are two different cases.
For k > 0
[tex]\frac{e^{ikz}}{z-i\epsilon}[/tex]
pole : z=iε
residule is e^(-kε)
so f(k) = e^(-kε)
for k<0
[tex]\frac{1}{(e^{imz})(z-i\epsilon)}[/tex]
where m=|k|
pole: z=iε
residule: e^(mε)
so f(k) = e^(|k|ε)
umm...how to prove that they equal to 1 or 0?
Microzero said:
For k > 0
pole : z=iε
residule is e^(-kε)
so f(k) = e^(-kε)
for k<0
where m=|k|
pole: z=iε
residule: e^(mε)
so f(k) = e^(|k|ε)
You might start by listening to what I'm saying. I've said that you need to take the limit of epsilon going to zero. And I've also said you need to think about what your closed contour looks like. What does the closed contour look like in both of these cases? After all, this is contour integration. You'd better start with a contour.
contour: consider a semicircle with inf. radius
that is just wht I have learned to solve this kind of integral from book
Sort of. That's not very complete or specific. You need a different contour for each of the two cases. What's the difference?
now I can prove that the integral is 0 when k< 0
but...for k>0...i still can;t show that it equals to 1...unless assume that ε → 0...
but the question just say that ε > 0
If you don't take the limit, then the integral is just e^(-k*epsilon). Not 1. But using i*epsilon in a problem like that is almost always a shorthand for 'epsilon>0 and approaching 0'. They may not have bothered to say that explicitly.
oic~~~~
thx~~~
