| Thread Closed |
Weir flow |
Share Thread | Thread Tools |
| Oct14-08, 03:35 PM | #1 |
Weir flow
ok i have a problem, i did a experiment to find the weir flow. Using q= cd 2/3 b root (2g) x h^(3/2) I measured b the width of the weir and the height. i was asked to find out the discharge coefficient cd. what i did was add weight to an unknow mass. so the original mass mass flow was x then we added 2.5kg each time. so to find to the flow q i do x (unknow mass) /time. I know have two unknow variables x and cd, where cd isnt constant. so i cant equate two readings. is cd was constant then u could. 2. Relevant equations q= cd 2/3 b root (2g) x h^(3/2) 3. The attempt at a solution ive given up |
| Oct15-08, 06:01 PM | #2 |
Are not coefficients constants?
| Oct16-08, 02:33 AM | #3 |
i got it now, the coefficients aren't constant. the coefficient for the rectanglular flow is cd=0.611 +h/z. so i can get the mass. and for the triangular weir cd is 0.58. but because my results are wrong. i cant sub these values into the equation to get the original flow, then the mass.
| Oct16-08, 06:17 PM | #4 |
Weir flow
It's been a long time since I worked these kinds of problems. From my old text it mentions that (note K=cd):
| Thread Closed |
| Thread Tools | |
Similar Threads for: Weir flow
| flow problem with a two diemsional water flow divider | Mechanical Engineering | 0 | ||
| Transition from pipe flow to open channel flow | Mechanical Engineering | 6 | ||
| Can an inviscid flow rotational? Potential Flow? | Mechanical Engineering | 2 | ||
| Temp flow and electrical flow | Classical Physics | 5 | ||
| water falling over a weir | General Physics | 2 | ||
