How Do You Solve the Limit of (5-x) / (3 - sqrt(x^2 - 16)) as x Approaches 5?
  • Thread starter Thread starter Alexstre
    Limits Zero
The discussion revolves around finding the limit of the expression (5-x) / (3 - sqrt(x^2 - 16)) as x approaches 5, which falls under the topic of limits in calculus.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants explore simplifying the denominator and multiplying by a conjugate, while questioning the validity of their algebraic manipulations. There is also a discussion about the interpretation of the limit resulting in an indeterminate form (0/0).
The conversation is ongoing, with participants providing feedback on each other's attempts and questioning assumptions. Some guidance has been offered regarding algebraic checks and interpretations of the limit, but no consensus has been reached on the correct approach.
Participants are navigating through potential algebraic errors and the implications of reaching an indeterminate form in their calculations. There is an emphasis on ensuring the accuracy of simplifications and interpretations of the limit.
Alexstre
Hello!
I'm trying to find the following limit:
[tex]{\lim_{x \to 5}}\ {5-x \over {3-\sqrt{x^2 -16}}[/tex]
I tried 2 things
Simplifying the bottom:
[tex]3-\sqrt{x^2-16}[/tex] = [tex]3-\sqrt{x^2-4^2}[/tex] = 3-x-4 = -1-x
But that doesn't help with what's on top...
I also tried multiplying top and bottom by:
[tex]3+\sqrt{x^2-16}[/tex] but I still ended up with 0/non-zero.
Could anyone point me into the right direction, or correct me if one of those 2 steps was right?
Thanks!
How do you figure Sqrt(x^2 - 4^2) = x - 4?
Have you thought of differentiating the numerator and the denominator, then taking the limit of their ratio?
If the limit is zero over non-zero, the limit is just zero. But in this case I'm getting the limit to be 0/0, yeah?
Alexstre said:
Hello!
I tried 2 things
This is wrong. [itex]\sqrt{x^2- 4^2}[/itex] is NOT x- 4.
Good! That prevented you from getting the wrong answer!
Really? WHAT did you get when you did that? I do NOT get "0/non-zero".
Thanks!
I recommend you recheck your algebra. In particular, what is
[tex]\left(\frac{5-x}{3-\sqrt{x^2- 16}}\right)\left(\frac{3+\sqrt{x^2- 16}}{3+\sqrt{x^2- 16}}\right)[/tex]
By the way, as MATdaveLACK said, there is nothing wrong with getting "0/non-zero": that would just mean the limit is 0. However, here, that is wrong.
