Solving EM Wave Emission from Cavity at T: Power per Unit Area
The problem involves a cavity at temperature T emitting electromagnetic (EM) waves isotropically, with a focus on determining the power per unit area that passes through a specific solid angle. The original poster is attempting to derive the effective Poynting vector magnitude per unit solid angle and relate it to the average energy density using Planck's Law.
  • Exploratory, Assumption checking
  • The original poster expresses uncertainty about the relationship between the Poynting vector and solid angles, questioning whether the integration over a solid angle of 2 pi is appropriate for the problem. Some participants clarify the need to consider the total solid angle of 4 pi and discuss the implications of integrating over different solid angles.
The discussion is ongoing, with participants exploring different interpretations of the solid angle integration and its impact on the results. Some guidance has been provided regarding the correct solid angle to consider, but no consensus has been reached on the original poster's approach to the problem.
The original poster notes that the unit system is Gaussian, which may influence the interpretation of the equations involved. There is also a mention of confusion regarding the integration limits and the specific requirements of the problem.
phystudent17
Basically, the problem states that a cavity at temperature T is emitting EM waves isotropically in all directions (with frequency distribution of Planck's Law). If the time averaged density is <e>, find the value of d<S>/dw where w is the solid angle and the quantity is the effective poynting vector magnitude per unit solid angle. Hence I am to show the power per unit area that passes in one direction (i.e. into solid angle of 2 pi) through any plane within the cavity is dP/dA= (c/4)<e>/ Note that the unit system is Gaussian. Basically, I am stuck at the first part of the problem.
Some equations that I know are <S>=c<e>, the total solid angle for a sphere is 4 pi.
I have a feeling the solution is really simple but I cannot get into the physics of it. Is d<S>/dw just <S>/ 4pi= (c/4 pi)<e>? But then integrating over a solid angle of 2 pi gives me (c/2)<e> which is off by a factor of 2. And I really don't get the solid angle business. Can someone point me in the right direction? Thanks.
"But then integrating over a solid angle of 2 pi gives me (c/2)<e> which is off by a factor of 2"
That's because you should be integrating over a solid angle of 4 pi, as you already know!
but now i want the power per unit area passing through one direction and that has a solid angle of 2 pi not 4 pi. the qn requires me to show that integrating over the solid angle of 2 pi gives me (c/4)<e>
I did misread your question, sorry about that. In any case, the relation |<\vec{S}>|=c<e> holds for plane waves propagating in a given direction. It's not a general relation.
