Rotational motion and gravitational torque
The discussion focuses on calculating the center of gravity and gravitational torque for two beams joined at right angles. The vertical beam weighs 15.0 kg and is 1.00 m long, while the horizontal beam weighs 25.0 kg and is 2.00 m long. The center of gravity was calculated using the equations Xcg and Ycg, resulting in coordinates of (1.25 m, 0.375 m). The gravitational torque was computed as Tnet = -122.5 Nm, indicating a clockwise rotation due to the negative torque from the horizontal beam.
  • Understanding of center of gravity calculations
  • Familiarity with torque equations and their applications
  • Knowledge of gravitational force (g = 9.8 m/s²)
  • Basic principles of rotational motion
  • Study the concept of center of mass for composite bodies
  • Learn about torque calculations in static equilibrium
  • Explore the effects of gravitational forces on rotational systems
  • Investigate the application of torque in engineering and physics problems
Students in physics, engineering professionals, and anyone interested in understanding the principles of rotational motion and torque calculations.
brethman86
1. There is a figure showing two thin beams joined at right angles. The vertical beam is 15.0 kg and 1.00m long and the horizontal beam is 25.0 kg and 2.00m long.
Part a) askes to find the center of gravity to the two joined beams, taking the origin at the corner where the beams join.
Part b) calculating the gravitational torque.
2. Homework Equations : Xcg= (x1m1 + x2m2 + ...)/ (m1 + m2 +...)
Ycg= (y1m1 + y2m2 + ...)/(m1 + m2 + ...)
torque net= t1 +t2
t1=-x1m1g
t2=+2m2g
Tnet =T1 + T2
3. I have no idea where to start this problem. We do problems similar in class but with a mass at each end of a "massless" rod.
Starting off the right angle is oriented so the 25 kg 2.00 m bar would run along the + x-axis and the 15 kg 1.00m bar would run along the + y axis.
I set x1 m1 t1 as the 25 kg 2m bar.
To calculate the x coord for center of gravity I did Xcg= (25.0kg)(2.00m)+(0m)(15.0kg)/(25.0kg+15.0kg)
= 1.25m
I used zero as m2 because I did not think it would contribute to the x coord system.
Ycg= (1.0kg)(15.0kg)+(0m)(25.0kg)/(25.0kg + 15.0kg) = .375m
so for part A I got (1.25m+.375m)
Part B)
I set toque 1 for the 2m bar. T1= -x1m1g (neg because it want to rotate CW) so T1= -25kg(1.25m)(9.8m/s^2) = -306.3 Nm
torque 2 was for 1.0m bar. T2= +x2m2g T2 (I figured it would want to undergo CCW rotation motion so I thought it would be +) T2= +15kg(1.25m)(9.8m/s^2) =183.75 Nm
Toque net =T1+T2 -306.3 Nm + 183.8Nm = -122.5 Nm
I would really like some help in the equations and setting up. I feel like 122.5 Nm is to large of a torque.
Your center of mass is wrong. You can calculate the center of mass of a bunch of beams by treating each beam as if it were a point particle located at its own center of mass, which should be half-way along the beam. In other words, use the half way points of the beams rather than the end points of the beams.
29K
