| Thread Closed |
How much work a battery does connected to a resistor |
Share Thread | Thread Tools |
| Oct21-08, 07:22 PM | #1 |
A battery has an EMF of 12.0 volts and internal resistance of 3 ohms A 21.0 ohm resistance is connected to the battery. 0.5 Amps flow through the battery, hence 0.5 Amps flows through the 21.0 ohm resistor The potential difference across the 21 ohm resistor is 10.5 Volts, hence the terminal voltage of the battery is 10.5 Volts. The question is How much work does the battery connected to the 21.0 ohm resisitor perform in one minute? 2. Relevant equations Voltage = Joule/coloumb 1 amp = coloumb/ second = (6.258 *10^18 electrons) second 1 electron has a charge -1.60*10^-19 coloumbs 3. The attempt at a solution current = 0.5 Amps = 3.125*10^18 electron/ second = 30 coloumbs pass wire per minute usisng the definition of EMF (voltage): 30 coloumbs/ minute * 10.5 volts = 315 Joules however it keeps on telling me that answer is wrong i know its simple i just can't see it right now thanx |
| Oct21-08, 07:43 PM | #2 |
1 amp x 1 volt = 1 coul/sec x 1 joule/coul = 1 joule/sec = 1 watt
| Mar17-09, 03:25 PM | #3 |
| Mar17-09, 03:43 PM | #4 |
My thought on your problem is as follows.
You have a terminal Voltage of 10.5 V, EMF of 12V, Flow of 1/2 A..so pretty much everything you need. Use the equation for Work on a Resistance : [latex]W=I^2 R t [/latex] where R=r the resistance of the battery. That gives you 45 Joules produced in 60s = 1minute. I don't take it for granted that I am correct! |
| Mar17-09, 04:45 PM | #5 |
30 C/min * 12 (J/C) = ___J/min |
| Mar17-09, 05:06 PM | #6 |
Mentor
| Thread Closed |
| Thread Tools | |
Similar Threads for: How much work a battery does connected to a resistor
| analyzing circuits with resistor/battery | Introductory Physics Homework | 5 | ||
| [SOLVED] Battery with internal resistor | Introductory Physics Homework | 3 | ||
| A battery-battery-resistor circuit | Introductory Physics Homework | 2 | ||
| Three capacitors connected to a battery | Introductory Physics Homework | 1 | ||
| Resistor connected in series with a capacitor? | Introductory Physics Homework | 4 | ||
