Finding Acceleration & Tension in a Frictionless Pulley System | Homework Help
  • Thread starter Thread starter nns91
The problem involves a frictionless pulley system with three masses: one on a horizontal shelf and two hanging. The original poster seeks to determine the acceleration of the masses and the tension in the strings after the system is released from rest.
  • Participants discuss the need to find the acceleration of the masses, suggesting that they can be treated as a single system. There are mentions of using free body diagrams (FBDs) to identify forces acting on each mass and applying Newton's second law.
Some participants have provided guidance on setting up equations based on the forces involved, while others express confusion about how to proceed without knowing the acceleration. There is an ongoing exploration of the relationships between tension and acceleration, with some participants questioning the assumptions made in their setups.
Participants note the importance of considering the tension in the strings and the implications of the system being frictionless. There is also mention of potential variations in future problems, such as those involving inclined planes.
nns91
A bos of mass m2= 3.5 kg rests on a frictionless horizontal shelf is attached by strings to boxes of masses m1= 1.5 kg and m3= 2.5 kg, which hang freely. Both pulleys are frictionless and massless. The system is initially held at rest. After it is released, find (a) the acceleration of each of the boxes, and (b) the tension in each string.
If you are confused about the graph, imagine the the m2 is in the middle with 2 strings on 2 sides, at 2 ends of the shelf there are 2 pulleys and m1 hangs on the left of the shelf and m3 hangs on the right of the shelf.
F=ma
I tried to get the Tension at rest but it not going to do anything with the final answer.
Guys, I need some help really quick
Ok, this is rather long.
First you need to find the acceleration of the masses. The acceleration of all the masses is the same. So, for now look at the three masses as one big box (added them up to together). Then draw the forces pulling them each way. (There should be two).
Then use F= ma
subtract the smaller force from the larger force, because the force is net force, and solve:
so it should be set up like this:
winner force- loser force = mass(of entire big blog) * a
You are going to have to show some work. You will need to identify the forces acting on each block, and apply Newton's 2nd law to each. Are you familiar with free body diagrams?
hi,
Draw the diagram
draw a free body diagram for each box (remember the tensions in each string may be different).
If the strings are taut and unstretchable, what can you say about the accelerations of each body?Now you should have lots of equations! Solve!
How do I find the acceleration ? Does it involve tension here ??
I did draw FBD for each box and creates some 2nd law equation:
T1-m1g=m1a1
m3g-T3=m2a2
T3-T1=m2a2
What do you guys thinks ?
I posted how to find the acceleration. forget about the tension until you find the acceleration. (you need acceleration to find the tension)
I mean how do you find the force since we don't know a ?
you can't
so how can I use your formula:
to find a ?
find a, then find tension. It's the only way.
I know that so how do you find a ? Which formula do you use ?
look at my first post
That's what I thought you wrote. So I can find the mass. How about the winner force and loser force ??
the winner force and the loser force come from the boxs hanging down. Since they are hanging, they have weight, so: mg
so we ignore the tension there ?
Now I get it. Sorry I am a little too dumb tonight.
it's alrgiht. Tell me when you get the acceleration, and then I'll help with the tension. (there are two)
I got 1.31 m/s^2. Is that right ?
Now what's next ?
Do we use 2nd law again as:
T1-m1g= m1a ?
m3g-T3=m3a ?
sorry, I actually have not done the calculations. but the set up for the next part looks right!
T1-m1g=m1a1
m3g-T3=m2a2you meant to say m3g - T3 = m3a3[/color]
T3-T1=m2a2
Except for the typo in your second equation, which you have corrected in your last post, your equations are good. And since the accelerations of each block are equal, a1=a2=a3, so just call it a. Solve the three equations with the 3 unknowns (T1, T3, and a) and you're done. Drawing good free body diagrams are important in solving most problems involving Newton's laws.
Thank you. That helps a lot. I was kinda dummy when not thinking about that the acceleration is same for 3 of them.
What if in another problem, there is a m1 on an inclined plane (with angle x), on top of the inclined plan, there is a pulley and m1 is connected to m2 (hanging freely) through a string through the pulley.
How do I solve this one ?
I know that acceleration for m1= g sin x. What will be the acceleration of m2 ? Will it be the same ??
As long as the blocks are connected by a taut inextensible string wrapped around a massless frictionless pulley, the magnitudes of their accelerations will be the same. However, the acceleration for m1 is not gsinx; you have to consider the string tension as well in your free body diagram for each block. And depending on the values of m1 and m2 ,m1 might be moving down the plane , or up the plane, or not moving at all!
If so, how can you find ound the acceleration for m1 ?
Just like you did in the previous problem, draw a FBD of each block. You willend up with 2 equations with 2 unknowns (T and a). Solve for each. If the block are not moving, 'a' will come out to zero. Otherwise, if 'a' comes out to a positive or negative number, it's moving one way or the other.
Oh yeah, I know what you mean.
  • · Replies 18 ·
  • · Replies 17 ·
