Solve Algebra 2 Problems 3, 7, 9 & 19
  • Thread starter Thread starter mustang
    Algebra Algebra 2
The thread discusses several Algebra 2 problems, including systems of equations, properties of linear equations, the equation of an ellipse, and function composition. Each problem presents unique challenges that require different mathematical approaches.
  • Mixed
  • Participants explore the relationships between variables in Problem 3, suggesting the formulation of equations based on given conditions. There is a focus on isolating variables and substituting them into equations. For Problem 19, there is a discussion about the process of function composition, specifically how to evaluate one function within another.
Some participants have provided hints and partial approaches to the problems, particularly in Problem 3, where they emphasize the need to set up equations correctly. In Problem 19, there is an indication of how to proceed with the function evaluation, but no consensus or complete solution has been reached.
Participants are encouraged to show their work for better assistance, and there is an emphasis on understanding the relationships between the variables involved in the problems.
mustang
Problem 3. The sum of the two numbers is 3 and the sum of their reciprocas is 12/5. Find the numbers.
Problem 7. What is the linear term of the equation
q = 3x^2 + 2x - 1?
Problem 9. Write the equation of the ellipse with foci at (12,1) and (-12,1) and the endpoints of the major axis at (0,6) and (0,-4) Then graph the ellipse.
Problem 19. If f(x)=3x^2-2 and g(x)=2x^2+3, find[f o g](-4)
Problem 35. What have you done so far?
Problem 3.
Let your two unknown numbers be m and n. You're given two statements about the relationship between m and n. Each statement can be written as an equation. You'll have two equations and two unknowns. You can solve this system of equations simultaneously for m and n.
The first equation is absolutely trivial. Hint on the second: The reciprocal of m is 1/m .
Show us a little of what you've done so we can help a little more.
2 equations, 2 variables, 2 easy :biggrin:
[tex]x + y = 3[/tex]
Isolate one of the variables.
[tex]x = 3 - y[/tex]
Now write the other equation
[tex]\frac{1}{x} + \frac{1}{y} = \frac{12}{5}[/tex]
Substitute the isolated variable.
[tex]\frac{1}{3 - y} + \frac{1}{y} = \frac{12}{5}[/tex]
Now multiply each term by all of the denominators.
[tex]5y + (15 - 5y) = 36y - 12y^2[/tex]
Just solve for that equation and you'll have Y. Then substitute that answer for Y back into the first equation.
I think you are supposed to fill in -4 for the g equation, then use the g equation as x in the f equation. It's like this:
f(g(-4)) = ??
  • · Replies 24 ·
