Hang time, range, maximum height
The problem involves analyzing the motion of a football kicked at an angle, specifically determining its hang time, range, and maximum height. The context is within the subject area of projectile motion in physics.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the appropriateness of the equations provided for calculating range and height, with some questioning the inclusion of trigonometric factors. There is also a focus on clarifying how to correctly apply the sine function to the angle in the equations.
The discussion is ongoing, with participants identifying potential errors in the original equations and suggesting corrections. There is a collaborative effort to clarify the mathematical expressions needed for the calculations, but no consensus has been reached yet.
Participants are working under the assumption that air resistance is negligible and are focused on the correct application of trigonometric functions in their calculations.
itsmarasilly
Find the ball's hang time, range, and maximum height.
A player kicks a football from ground level with an initial velocity of 27.0 m/s, 60.0° above the horizontal. Find the ball's hang time, range, and maximum height. Assume air resistance is negligible.
Range = Initial Velocity ^ 2 /9.8
Height = (Initial Velocity)(Sin)^2/ (2)(9.8)
I'm not sure if these equations are correct.
Hi itsmarasilly,
This does not look right; it is missing a trig factor. Do you see what this formula needs to be?
This is not correct (although you might just have a typo in your equation). In particular, what is being squared here?
the 60 degrees? would it be put in the calculator as sin(60^2) or sin(60)^2, does it make a difference?
The vertical component of your velocity is 27 * Sin 60. That's what you square.
  • · Replies 38 ·
28K
  • · Replies 21 ·
