Thermodynamic Application Isothermal Work
The discussion revolves around a thermodynamic problem involving an ideal gas that performs isothermal work during expansion. Participants are tasked with determining the initial volume and temperature of the gas given specific work done and final conditions.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the relationship between work, volume, and temperature in the context of isothermal processes, referencing the equation W = nRTln(vi/vf). There is uncertainty about how to isolate variables, particularly temperature and initial volume, given the constraints of the problem.
Several participants express frustration with the complexity of the problem and question the logical consistency of their calculations. Some suggest starting with the ideal gas law to find temperature, while others explore the implications of the work done on the initial volume. There is no explicit consensus, but multiple lines of reasoning are being explored.
Participants note the importance of unit consistency, particularly when converting volume from liters to cubic meters. There is also mention of the potential for illogical results if assumptions or calculations are incorrect.
latitude
One mole of an ideal gas does 3000 J work on its surroundings as it expands isothermally to a final pressure of 1 atm and volume 25 L. Determine a) initial volume and b) Temp of gas
Well, its isothermal, so Temp is constant, so
W = nRTln(vi/vf)
It says it expands, so the initial volume is <25 L...
that's kinda all I got right now; I'm not sure how to get the next step, since both T and vi are in the equation. It must have something to do with pressure.
W = nRTln(vi/vf)
How do you find the temperature of the gas? Find that and then determine what ln(vi/vf) has to be if W=3000J.
AM
PV = nRT
(1.013 x 10^5)(10 m^3) = (1)(8.314)T
T = Some really big, way illogical number? Unless the moles thing is wrong...
ARGH. This one is frustrating me. I'm wondering if I don't have to find volume first??
Oooh...
3000 J = nR(PV/nR)(ln(vi/vf))
3000 J = (10.13 x 10^5)(25 L) ln(vi/25)
1.184 x 10^-3 = vi/25
vi = 0.029 L??
Possible??
EDIT: No, cause my final temp is still 304606.7 K !
latitude said:
Oooh...
vi = 0.029 L??
Possible??
Start with PV=nRT
[tex]P_iV_i = nRT = P_fV_f[/tex]
You know [itex]P_f, V_f[/itex] and n so work out T. Be careful to use the correct units for volume. Units are litres or 10^-3 m^3.
Then, from W = nRTln(vi/vf), work out what vi is.
AM
  • · Replies 33 ·
  • · Replies 17 ·
