Displacement of a point on a string given t and x
The problem involves finding the transverse displacement of a point on a string described by a wave equation. The equation given is y(x,t) = (3.50mm)sin[(t/162s) - (x/42.5)], and the task is to evaluate this at specific values of time and position.
  • Participants discuss the correct form of the wave equation and whether the original equation provided is accurate. There is confusion regarding the substitution of values for t and x, with some participants questioning the division versus multiplication of these variables in the equation.
The discussion has revealed differing interpretations of the wave equation, with some participants suggesting that the original equation may be incorrect. A participant identifies a potential error related to calculator settings affecting the results. There is an ongoing exploration of the implications of these interpretations without a clear consensus on the correct approach.
Participants note that the original equation was presented differently in the homework, leading to confusion. There is also mention of the need to ensure calculator settings are appropriate for the calculations being performed.
beccaka2003
The equation describing a transverse wave on a string is
Find the transverse displacement of a point on the string when t = 0.220 s and at a position x = 0.140m
y(x,t) = Asin(wt-kx) or y(x,t) = Asin2pi[(t/T)-(x/wavelength)]
k = 2pi/wavelength
w = 2pif
I know from previous parts of the problem that I got right:
wavelength = 0.148m
f = 1/T = 25.8 Hz
A = 3.5mm
I thought that you would just plug the values of t and x into the second equation I gave, but it was wrong. I keep on coming up with y = 1.73, no matter what I do, but the answer is y = -3,46. What am I doing wrong?
Hi beccaka2003,
This is the equation that you want to plug your t and x value into. But isn't this equation wrong? I have found a form that matches the frequency and wavelength you said you got on the previous parts of the problem, and it does not match the above formula.
So please check and fix this equation. Do you get the right answer?
No, that is the equation that we are given. In the homework, it was written slightly different, but I'm positive they are the same:
y(x,t) = (3.55mm)sin[(162s^-1)t-(42.5m^-1)x]
They are the same, right? I got the correct answers for the first 3 parts of the question using it.
I really want to understand this, and it is driving me nuts.
beccaka2003 said:
No, that is the equation that we are given. I double checked. That is why I'm so confused. It should be simply substituting the values in, right? I really want to understand this, and it is driving me nuts.
From your wavelength and frequency values:
wavelength = 0.148m
f = 1/T = 25.8 Hz
I'm getting that the w and k values are:
w=162 rad/s
k=42.5 m-1
If you then look at your general equation:
you can see that t is multiplied by w, not divided; and x is multiplied by k, not divided. So I think your original equation should not be:
it should be:
y(x,t) = (3.50mm)sin[(162) t - (42.5) x]
Are you sure your book did not have it in this form? I'm confused as to how you could have gotten the correct wavelength and frequency if it was not in this form.
(Also, change your calculator from degrees to radians!)
(I was responding to your post while you were still modifying it, so you might not have seen my last post.)
No, they are not the same. The s-1 and the m-1 are units; the numbers 162 and 42.5 stay in the numerator.
(And be sure to read in my last post about changing your calculator from degrees to radians.)
Ahh! Its all because my calculator was in degrees, not radians. The reason the other equation worked for me was because I had taken the long way around and made the equation y(x,t) = (3.50mm)sin2pi[(t/25.8s) - (x/.148)]. That should have told me right there that y(x,t) = (3.55mm)sin[(162s^-1)t-(42.5m^-1)x] is not equivalent to
y(x,t) = (3.50mm)sin[(t/162s) - (x/42.5)]. Silly mistake that made a really simple problem impossible. Thanks so much!
Sure, glad to help!
