Thread Closed
How much effort do you think it would take to make your own card access system?
Share Thread Thread Tools
Oct22-08, 11:04 PM   #1
I know you can get the parts to make a magnetic reader for around 40 to 60 dollars. I also know (from reading 2600 mag) that you can access the magnetic strip of your credit card and rewrite the data inside it. I think it is possible to get the magnetic reader to communicate with your keyboard if you solder them together. Given this, it is possible to make a security card access system to something like a door?
Disowned, what the hell do you mean by card access system?
Well, I mean is basically a security that revolves around your card as the key to unlock that system. Maybe I'm not explaining it correctly but someone out there has to know what I am talking about.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Nov6-08, 03:24 PM   #2
Admin
Why would you connect the reader to your keyword? Not USB to your PC with custom program?
Nov6-08, 04:18 PM   #3
Well I theorizing a system that could operate without interaction from the PC. A standalone program, if you will, where the lock system would be operated by the card reader, a monitor, and the keyboard.
However, given what you said, it would much easier to do this if I took an old RTV unit and PC and hooked it up to the reader and keyboard. Not that I have the money or time to embark on this project anyway.
Nov6-08, 05:42 PM   #4
Recognitions:
Homework Helper Homework Help
Bar code readers connect to the keyboard port and send the key scan codes as if you had typed on the numeric keypad - I suppose a card key could do the same. The advantage of this is that you don't need to change the software.
But you would need someway of signalling back to the lock wether or not it should open.
Thread Closed
Thread Tools
Similar Threads for: How much effort do you think it would take to make your own card access system?
Thread Forum Replies
C++ programming(access to sound card) Programming & Comp Sci 6
Suppose we change the axis of the earth and make it vertical to the solar system... General Astronomy 7
What make system different from environment? Quantum Physics 2
TechRepublic's Quick Reference: Microsoft Access Pak helps you understand Access features Computing & Technology 0
