Interpreting this wave funtion
  • Thread starter Thread starter RJS
    Wave
The discussion focuses on interpreting the wave function y(x,t)=[(4.8mm)sin(x/3.6m)cos(130rad/s)t] to extract amplitude, wavelength, and velocity. The amplitude is confirmed as 2.4mm, derived from the equation's peak value. To find wavelength, the wave number k is utilized, and velocity is calculated using the relationship between angular frequency and frequency. Participants emphasize the necessity of reworking the equation using trigonometric identities to separate the combined wave functions into y1(x,t) and y2(x,t).
  • Understanding of wave functions and their properties
  • Familiarity with trigonometric identities and manipulation
  • Knowledge of wave parameters: amplitude, wavelength, frequency, and velocity
  • Ability to apply the wave equation in the form y(x,t)=Acos(kx-wt+phi)
  • Study trigonometric addition identities to express sin(a)cos(b) in solvable forms
  • Learn how to derive wave parameters from wave functions
  • Explore the implications of wave interference and superposition
  • Practice manipulating wave equations in different forms for better comprehension
Students studying physics, particularly those focusing on wave mechanics, as well as educators seeking to clarify wave function interpretations and manipulations.
RJS
find Amplitude, wavelength and velocity of wave from the two combined waves.
there are two waves here, combined into one, show each wave function: y1(x,t) and y2(x,t).
ok, i can fully manipulate the wave function when it's in it's basic form of y(x,t)=Acos(kx-wt+phi) but i must be missing something here. is the problem in a form that can be worked or must it be reworked with a trig function? it's all being multiplied so I'm not sure how to get it into the (kx-wt) format.
any help would be appreciated.
thanks.
because they are two waves in this equation Amplitude is (4.8mm/2)=2.4mm... correct?
wave length can be found using kx= [2(pi)x]/(lambda) and velocity will be found using wt=2(pi)tf to find frequency and then v=(lambda)(frequency)
my question is do i need to change the equation? or can i just use it as is?
I don't have the answer to this question, so if you can point me in the right direction?
You're correct on amplitude, wavelength, frequency and velocity.
In addition, yes you will need to change the equation, since it asks explicitly to "show each wave function: y1(x,t) and y2(x,t)."
If you can figure out how to express
sin(a)cos(b)
in terms of
sin(a+b), sin(a-b), cos(a+b), and/or cos(a-b)
using trig-addition identities, then it is solvable.
9K
  • · Replies 21 ·
