Electric potential due to line of charge
The discussion revolves around calculating the electric potential due to a line of charge with a non-uniform charge density. Participants are exploring the appropriate equations and methods to apply in this context.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • The original poster attempts to apply a formula for electric potential but finds it does not suit the non-uniform charge density of the problem. Some participants suggest integrating the charge density to find the potential, while others question the applicability of the initial formula used.
Participants are actively discussing the need for a different approach due to the non-uniform charge distribution. Guidance has been offered regarding the integration of charge density, and there is an ongoing exploration of how to set up the integral correctly.
There is an emphasis on the distinction between uniform and non-uniform charge densities, which affects the choice of formulas and methods for calculating electric potential. Participants are also addressing the need for clarity on the charge distribution along the line of charge.
stickyrice581
http://img239.imageshack.us/img239/9112/54077471xz4.jpg
http://img183.imageshack.us/img183/1450/clipboard01bt7.jpg
The online chapter gave me the above equation for the potential due a continuous charge. I converted pico coulomb to coulomb and cm to m. I also did charge times length for lambda. I got .0644 Volts and the site says its wrong. So then I tried charge divided by length for lambda. I got 3.28 Volts and it's also wrong. Any ideas?
Hi stickyrice581,
The formula that you have does not apply to this situation. That formula was calculated for a uniform charge density. However, in your problem the charge density is different at different parts of the rod.
So you'll need to calculate an analogous formula for your case. What do you get?
I think you have to integrate the charge density for Q. It actually greatly simplifies the integral.
V = k*int(dq/x) from .05m to .19m
Now the trick is rewriting the dq in terms of dx
Is there a formula I can use for my problem?
king vitamin gave you the formula in his post:
[tex] V = k \int \frac{dq}{r}[/tex]
where the integral is taken over the charge distribution.
If you look in your book where you found the formula you have in your first post, you should see how they use this integral for the uniformly charged rod. Just follow the same type of procedure, using the fact that this rod is non-uniformly charged.
