Finding null space of a given matrix
The discussion revolves around finding the null space of a given matrix A, specifically the matrix A = [1 3 2; 2 6 4]. Participants are tasked with determining the null space NS(A) and sketching it in R2 or R3.
  • Participants discuss the relationship between the rows of the matrix and their implications for solving AX = 0. There is an exploration of reducing the matrix to row echelon form and the assumptions made about the variables involved. Some participants question the validity of assuming specific values for the variables.
The discussion is ongoing, with various interpretations being explored. Some participants have provided guidance on how to approach the problem, including suggestions for handling free variables and the implications of the row echelon form. However, there is a lack of consensus on the understanding of concepts like basis and the specifics of the null space.
Some participants express uncertainty regarding the concept of a basis and the level of detail expected in their responses, indicating that they have not yet covered certain topics in their coursework.
Maxwhale
Find null space of A, NS(A) and sketch NS(A) in R2 or R3.
A = [1 3 2; 2 6 4]
AX = 0
I know the second row is twice the first one. I tried to solve for x1, x2 and x3 putting everything in the form of AX =0. I did not get a confident answer to sketch.
What did you get?
since there are three variables, x1, x2 and x3, i reduced them to row echelon presuming that x3=0 and then got x1=0 and x3=0. Is that a right way?
What do you mean? The null space of A is a set.
Either say NS(A) is the set of vectors (x, y, z) such that ... or, perhaps simpler, give a basis for the Null Space.
We are not that far yet. We have not covered basis. I would really appreciate if you could put it simply so that i could understand. Please :)
A = [1 3 2; 2 6 4]
AX = 0
You cannot assume x3 equals any specific number. The nullspace of A is all vectors <x1, x2, x3> such that
[tex]\left[\begin{array}{ccc} 1 & 3 & 2 \\ 2 & 6 & 4 \end{array}\right]\left[\begin{array}{c} x1 \\ x2 \\ x3\end{array}\right]= \left[\begin{array}{c}0 \\ 0 \\ 0 \end{array}\right][/tex]
You can row reduce that as you said you did: the bottom row will be 0, of course, the top row [1 3 2 0] which corresponds to the equation x1+ 3X2+ 2X3= 0. Since that is single equation in 3 unknown numbers, you can choose two of them to be whatever you want and solve for the third. If x2= 1 and x3= 0, what is x1?. If x2= 0 and x3= 1, what is x1?
What is the dimension of NP(A)? What is a basis for NP(A).
You can,
The matrix A which you gave has one pivot column making the other two columns free.
n-r = 3-1 = 2, the dimension of the nullspace is 2.
Set the free variables to 1 and 0, and use back substitution to find the missing variable in your nullspace vector. You should get:
s_1 = [-3, 1, 0] and s_2 = [-2, 0, 1], with dimension 2.
I'm pretty sure that's right.
If you do not know what a basis is then I guess that by "find the null space" you are meant to just write the equation satisfied by points in the null space. As you said, the two equations are equivalent so any such point must satisfy x+ 3y+ 2z= 0.
What is the graph of that?
