Hello How to prove the min function is continuous?
The discussion revolves around proving the continuity of the minimum function, specifically for two functions \( f_1 \) and \( f_2 \) mapping from a set \( X \) to the real numbers, where \( f_3 = \min\{f_1, f_2\} \). The scope includes theoretical aspects of continuity and mathematical reasoning.
  • Exploratory, Technical explanation, Homework-related, Mathematical reasoning
  • One participant inquires about how to prove the continuity of the function \( f_3 = \min\{f_1, f_2\} \).
  • Another participant presumes that \( f_1 \) and \( f_2 \) are continuous and suggests separating the analysis into cases where \( f_1(x) \neq f_2(x) \) and \( f_1(x) = f_2(x) \).
  • A later reply mentions using the gluing lemma as a convenient approach to construct the proof.
  • Another participant provides a quick solution by expressing the minimum function in terms of \( f \) and \( g \) using the formula \( \min(f, g) = \frac{f+g}{2} - \frac{|f-g|}{2} \).
Participants have not reached a consensus on the proof method, and multiple approaches are presented without resolving which is preferable.
Assumptions about the continuity of \( f_1 \) and \( f_2 \) are not explicitly confirmed, and the discussion does not clarify the implications of the cases suggested for the proof.
simpleeyelid
Hello!
Could anybody give me an idea about this proof?
knowing [tex]f_{i}:X\rightarrow[/tex]R i=1,2
to show whether [tex]f_{3}=min{f_{1},f_{2}}[/tex] is continuous!
Thanks in advance,
Regards
Presumably f1 and f2 are continuous themselves? Is this a homework problem? I'll give you a small hint: work on the points where f1(x)=/=f2(x) and f1(x)=f2(x) separately
yeah, thanks, a lot, I finally find that it is convenient to construct it using the gluing lemma.
quick solution:
min(f, g) = (f+g)/2 - |f-g|/2
