Magnetic flux / induced emf problem
The discussion revolves around a problem involving magnetic flux and induced electromotive force (emf) in a coil placed inside a solenoid. The problem includes calculations related to the magnetic field, flux, and the time it takes for current to reach a certain value in a different solenoid setup.
  • Participants explore the relationship between the coil and the solenoid, questioning how to determine the magnetic field inside the solenoid and its effect on the coil. There is an attempt to calculate the magnetic flux and identify discrepancies in the results.
Some participants have provided guidance on the correct formulas to use for calculating the magnetic field and magnetic flux. There is an ongoing exploration of the calculations, with some participants noting errors and seeking clarification on their results.
Participants express confusion regarding the conceptual understanding of the problem and the application of relevant equations. There is a focus on ensuring the correct use of physical constants and relationships in the calculations.
tombroz
A single coil with a radius of .02m is placed inside a 3m long solenoid that has 600 turns. The radius of the solenoid is 0.15m. The plane of the coil is perpendicular to the axis of the solenoid. The solenoid is connected to a battery, an ammeter and a switch. The ammeter reachs 5A in 0.2 seconds and remains constant.
a) What is the change in the magnetic flux across the small loop?
b) What is the average induced emf in the small loop?
c) Another solenoid has an inductance of 8.0 henries and a resistance of 2.772 Ohms. It is connected to a battery and a switch. How long does it take for the current to reach half of its maximum value after the switch is closed?
Ahhh... crap. This problem is hard for me.
I know the equation for magnetic flux is:
Phi = (B*A*cosPhi)
B is the magnetic field, A is area.
I don't know how the coil relates with the solenoid. Should I first figure out what is going on inside the solenoid? Then from there I could figure out the emf of the single coil? I'm lost. I'm having trouble conceptualizing this problem. Any help is greatly appreciated. Thanks!
Absolutely! What's the field inside the solenoid? That's the field that is creating the flux through the coil.
Great.
The formula to find the field inside of a solenoid is B = Mu*Number of turns*Length of solenoid*I. Using this, I found the field to be 0.0113T.
Magnetic flux = BAcosPhi
When plugging in my B value from the field inside the solenoid and the area (Pi*r^2) of the coil and cos 0, my value is off. I get 1.42E-5. What I'm looking for is 1.58E-6.
Can you help me? Where did I go wrong?
The correct formula is μ*(N/L)*I.
Ahh yes...
using Mu*(N/L)*I, I returned a value of .0013 which fit nicely into my change in magnetic flux equation to give me the correct answer.
Thanks a lot!
