How fast must a magnet go to make visible light?
The discussion revolves around the relationship between the motion of a magnet and the generation of electromagnetic waves, specifically focusing on how fast a magnet must move to produce visible light. Participants explore concepts related to electromagnetic waves, photons, and the implications of special relativity in this context.
  • Some participants propose that moving a magnet generates electromagnetic waves, which can be interpreted as photons, and suggest that the speed of movement affects the energy of these waves.
  • Others argue that the energy of a photon is proportional to its frequency, and question how the speed of the magnet influences the energy of the generated electromagnetic wave.
  • A few participants mention that the apparent frequency of the emitted wave can change depending on the observer's frame of reference, particularly in the context of special relativity.
  • Some contributions clarify that a De Broglie wave may be produced by a moving magnet, but this does not necessarily correspond to the generation of a photon.
  • There are discussions about the conditions under which a moving magnet may produce electromagnetic waves, with references to specific research and theoretical frameworks.
Participants express differing views on the relationship between the speed of the magnet and the energy of the electromagnetic waves produced. There is no consensus on whether moving a magnet can produce photons or solely De Broglie waves, and the discussion remains unresolved regarding the conditions necessary for generating electromagnetic radiation.
Some limitations noted include the dependence on the observer's frame of reference, the conditions under which electromagnetic waves are generated, and the distinction between different types of waves produced by the motion of the magnet.
thenewmans
If I get this whole “Moving magnet and conductor problem” business at all, one frame’s electricity is another frame’s EM wave. So moving a magnet causes an electromagnetic wave, AKA: photon. I assume the faster you move it, the higher the energy of that wave/photon. (Maybe you have to vibrate it to get a frequency. Maybe acceleration is the key.) So how fast do you have to move it, vibrate it or accelerate it to get a photon in the visible spectrum out of it?
http://en.wikipedia.org/wiki/Moving_magnet_and_conductor_problem
429 THz (red light at 700 nm).
You may well "get it" but it should be stated "one frame's electric field is another frame's magnetic field"...each are different aspects of an electromagnetic wave...each will induce the same current...
I just noticed Wiki says it this way:
The magnetic field in the magnet frame and the electric field in the conductor frame must generate consistent results in the conductor.
which seems clear.
I'll be interested to see explanations to this and the rest of your question(s)...
A photon's energy is proportional to its frequency. About a wave, its energy is the number of photons times the energy of a single photon.
How does changing the speed of the magnet change the energy of the EM wave it generates?? The photon (or wave) always moves at the speed of light regardless of the velocity of the source.
or to say it another way: if the magnet is held stationary and I approach the magnet at some velocity, the apparent frequency increases but the energy of the wave I don't think posssibly could.
Note: see my post below for a revision of this idea...special relativity means frames of reference matter.
I think you are right. The energy of the wave is given only by the Poynting vector S=E x H. So, in my opinion there's no dependence on the velocity.
If you read my first post you notice I was talking about frequency (even the OP auto-suggested this fact). When you move a magnet in an alternating way, it generates an electromagnetic wave which has the same frequency; the amplitude of the wave, fixed the frequency, depends on the amplitude of the magnet's oscillation. The photon's energy depends only on its frequency, the amplitude of the wave depends on the number of photons. You can compute the energy that flows through a unit area in the unit time in two ways: classically and quantistically. In the first case you compute Poyinting's vector, in the second you compute a photon's energy and the number of photons traversing that area in the unit time and then multipying the two values.
Here's an explanation from
http://math.ucr.edu/home/baez/physics/Relativity/GR/energy_gr.html
Very fast objects emitting light
According to special relativity, you will see light coming from a receding object as redshifted. So if you, and someone moving with the source, both measure the light's energy, you'll get different answers. Note that this has nothing to do with energy conservation per se. Even in Newtonian physics, kinetic energy (mv^2/2) depends on the choice of reference frame. However, relativity serves up a new twist...
Nope. Moving a magnet creates a De Broglie wave but no photon. The De Broglie wave is not a true wave but more like a wake. It's not a traveling wave and therefore it's not accompanied by a photon. But you're right about the frequency part as it concerns the De Broglie wave.
Under what limitations do you expect moving a magnet to produce only an "empty" wave? Constant acceleration?
If I waggle a magnet around, I'm sure that can generate an electromagnetic wave which could transfer energy to an aerial.
Do you mean by "empty" wave one that isn't associated with a photon and that isn't self-propelled? (i.e. non-radiative)
If so, that's an excellent question that far too many researchers have overlooked IMO. That's really the physical end of QM. It's not quite as simple as the lack of acceleration or constant acceleration. There's a very interesting paper by the late Dr. Herman Haus in which he shows that the make or break condition for far field radiation is the existence of frequency components within the Fourier transform of the charge trajectory which are synchronous with the speed of light.
Haus H. A. "On the radiation from point charges", American Journal of Physics, 54,
(1986), pp. 1126-1129.
Related investigations have been documented by Tyler Abbott, David Griffiths, G. Goedecke and Philip Pearle.
  • · Replies 21 ·
  • · Replies 35 ·
  • · Replies 130 ·
18K
  • · Replies 28 ·
  • · Replies 48 ·
  • · Replies 33 ·
