| Thread Closed |
Mathematical Model of a Wind Tunnel Model |
Share Thread | Thread Tools |
| Oct30-08, 03:56 AM | #1 |
A wind tunnel model of an aircraft, representing only the rolling motion, is
constructed using two small lifting surfaces mounted in the horizontal (i.e. x – y) plane symmetrically on an axi-symmetric body. The body houses a set of ball bearings, which permit the complete model to roll about x – axis freely. Further, the right lifting surface (pointing towards positive y axis) is given an initial incidence of -3o with respect of the longitudinal axis of the body and similarly, the left lifting surface (pointing towards negative y axis) is given an initial incidence of +3o with respect of the longitudinal axis of the body. The wings have 5 cm chord, 30 cm span (for each half part) and are made of Aluminium. Generate the mathematical model of the above wind tunnel model in terms of the roll moment as the disturbance and roll attitude as the output from the system. |
| Nov14-08, 06:43 AM | #2 |
This looks like a homework problem.
Stick it in the HW section and if you need help completing it, then, as the forum guidlines state, you should supply your attempts at the problem, not just the question. We're not a tutorial answering service, but we are willing to help
| Thread Closed |
| Thread Tools | |
Similar Threads for: Mathematical Model of a Wind Tunnel Model
| Mathematical model of axial fan | Math & Science Software | 0 | ||
| Small wind tunnel for a model rocket | Mechanical Engineering | 15 | ||
| Mathematical model of inertia | Math & Science Software | 7 | ||
| Re: Predictions from Mathematical model | Math & Science Software | 3 | ||
| Wind Car, energy losses and model | Introductory Physics Homework | 5 | ||
