Why do calculators give a math error for sqrt(-1 * 1)?
  • Context: High School
  • Thread starter Thread starter SSan
    Explain
The discussion revolves around the mathematical error encountered when calculating the square root of a negative number, specifically sqrt(-1 * 1). Participants explore the reasons behind this error, particularly in relation to calculator settings and the nature of square roots in real versus complex numbers.
  • One participant notes that calculators may return a Math Error or Infinity when attempting to compute sqrt(-1 * 1), seeking explanations for this behavior.
  • Another participant suggests that the calculator is likely set to real mode, which does not accommodate complex numbers like i, the square root of -1.
  • A participant elaborates on the concept of square roots, explaining that there is no real number that can be squared to yield a negative result, thus leading to the calculator error.
  • One participant presents a mathematical manipulation involving square roots and imaginary numbers, though acknowledges that the reasoning may be misleading upon closer inspection.
  • Several participants provide examples of square roots of negative numbers, indicating that calculators below a certain model (TI-89) do not recognize imaginary numbers unless configured to do so.
  • There is a question raised about the TI-89 calculator's inability to return complex results, prompting a discussion about the settings that may allow for complex number calculations.
  • A participant expresses confusion about why calculators default to real mode if complex numbers are commonly used in mathematics.
Participants generally agree that calculators may not return valid results for square roots of negative numbers unless set to recognize complex numbers. However, there is no consensus on the appropriateness of defaulting to real mode or the implications of this choice.
Some participants highlight limitations in calculator programming regarding complex numbers and the necessity of changing settings to access these functionalities. There are also unresolved questions about the rationale behind default settings in calculators.
SSan
When I try to do :
sqrt(-1 * 1)
I come up with a Math Error or Infinity(varying on the caclulator used).
Explinations? :confused:
Mathematics news on Phys.org
The calculator is likely set for real mode. The calculation you're performing has i for an answer, and i is not a real number. Look for options with your calculator to give you a+bi output.
Good luck
Think about what the square root means. It's the answer to the question, "what do I have to multiply by itself to get to this number?" The square root of nine is the number that, when multiplied by itself, gives you nine - that number is three.
What about the square root of negative nine? Can you think of any number that, when multiplied by itself, gives you negative nine? Positive three times positive three is positive nine, that doesn't work. Negative three times negative three is still positive nine (remember, multiplying two negative numbers gives you a positive result.) There isn't any real number that you can multiply by itself and arrive at negative nine.
As a matter of fact, that's true for the square root of any negative number. Furthermore, it's true for any even root of any negative number. Your calculator is giving you an error because it's only designed or configured to display real numbers, and there aren't any real numbers that answer the question, "what is the square root of negative one?"
This reminds me of the following :
1 = SQRT(1) = SQRT(-1*-1) = SQRT(-1)*SQRT(-1) = SQR(i) = -1
Kinda clever for a couple of seconds, until you look at the first step again.
sqrt
sqrt(-1) = i
sqrt(-4) = 2 i
sqrt(-6) = 2.44948974 i
and so on...
Any calculator under TI-89 will give you an "nonreal ans" because they are not programmed to recongnized imaginary numbers unless otherwise told to.
I tried my TI-89 and it gives me an error when I try to do the Sqrt(-x); x being any numerical digit. Do you know of a way to remedy this, or is the TI-89 also a calculator which won't return i for an answer?
Your calculator should have a MODE button. If you press it a list of options should come up, and one of them should be "complex format". If it's set to "real" then complex numbers will not work.
thats odd .. why do they set the option in the calculator to that if most people will use complex numbers such as i?
  • · Replies 171 ·
13K
