How do I find the maximum compression of a spring?
The maximum compression of a spring can be calculated using the conservation of energy principle. In this scenario, a 4.5 kg crate moving at 2.0 m/s collides with a spring that compresses 0.10 m under a 5.0 N force. The spring constant (k) can be determined from the initial compression, and the kinetic energy (Ek) of the crate is calculated using the formula Ek = 0.5(mv)^2. By equating the kinetic energy of the crate to the potential energy stored in the spring (E = ky^2/2), the maximum compression (y) can be found.
  • Understanding of conservation of energy principles
  • Knowledge of kinetic energy calculations
  • Familiarity with spring mechanics and Hooke's Law
  • Ability to manipulate algebraic equations
  • Calculate the spring constant (k) using the formula k = F/x
  • Learn how to derive kinetic energy using Ek = 0.5(mv)^2
  • Explore the relationship between kinetic energy and potential energy in elastic systems
  • Study examples of energy conservation in mechanical systems
Students studying physics, particularly those focusing on mechanics and energy conservation, as well as educators looking for practical examples of spring dynamics.
lustish
A linear elastic spring can be compressed 0.10m by an applied force of magnitude 5.0N. A 4.5kg crate, moving at 2.0m/s, collides with this spring. What will be the maximum compression of the spring?
x= 0.10kg
F= 5.0N
m= 4.5kg
v= 2.0m/s
I'm not really sure, but I think that this is a law of conservation of energy problem...
E = E'
Eg+Ek+Ee=(Eg+Ek+Ee)'
Ek=0.5(mv)^2
I'm just really lost. Any help would be greatly appreciated!
This is indeed a problem of conservation of energy.
As the crate collides with the spring, at some point all the kinetic energy of the crate will have been transferred to the spring. The mathematical expression for energy stored in a spring is E=ky^2/2 where k is the "spring constant" (don't know this in english), and y is the displacement/compression of the spring.
You can find the spring constant from the first part of the problem, where you are told how much the spring compresses when compressed by a given amount of force. When you have k and have calculated the kinetic energy of the crate, you can solve for y.
Good luck!
10K
