Calculating L2 Lagrangian Point: A Beginner's Guide
  • Context: Undergrad
  • Thread starter Thread starter Irrelativity
    L2 Lagragian Point
The discussion revolves around calculating the L2 Lagrangian point, which is a position in space where the gravitational forces of two large masses balance the centrifugal force on a smaller mass. Participants explore the derivation of formulas for this point, including the use of approximation methods and polynomial equations. The conversation includes theoretical considerations and mathematical reasoning related to the L2 point's location in a rotating frame.
  • One participant seeks guidance on deriving a formula for the L2 Lagrangian point, emphasizing the need for approximation methods.
  • Another suggests working in a rotating frame centered at the center of mass of the two large masses, noting that the accelerations must sum to zero for a fixed point.
  • A participant mentions D'Alembert's principle and the fictitious nature of centrifugal force in the context of the problem.
  • Several participants discuss the polynomial equation derived for the L2 point, with one stating it is a fifth-order polynomial.
  • There is a proposal that the approximate solution for the distance from the smaller mass to the L2 point is r = R(m/3M)^(1/3), with discussions on how to arrive at this approximation from the polynomial.
  • Some participants express confusion about the survival of certain terms in the polynomial when approximating, leading to further exploration of the assumptions made in the derivation.
Participants express differing views on the nature of the polynomial derived for the L2 point, with some asserting it is fifth-order while others propose approximations that simplify the problem. The discussion remains unresolved regarding the best approach to derive the solution, indicating multiple competing views.
Participants note the importance of assumptions in their calculations, particularly regarding the relative sizes of the masses and distances involved. There is also mention of the limitations of first-order approximations in the context of the polynomial.
Irrelativity
Hi this is my first time posting on this forum. I have an question about Lagragian points.
I was trying to find L2 lagrangian point, a point that lies on the line defined by the two large masses, beyond the smaller of the two. Here, the gravitational forces of the two large masses balance the centrifugal force on the smaller mass. Let's say the larger object has mass M and the smaller object has mass m, and the distance between the two objects is R and the distance from the smaller object to L2 is r, then how do you guys derive a formula to calculate r? I was given a hint that I need to use approximation method meaning R is exceedingly greater than r such that (r/R)^2 is equal to zero. Again, Unlike L1 which is located between the two objects, L2 lies behind the smaller object.
At least if you can give me some hints, I would really appreciate. Thanks.
Astronomy news on Phys.org
Work in the frame with origin at the center of mass and rotating with the objects so that the location of the two massive objects in this frame is constant. The five Lagrangian points will also have a fixed location in this frame. The accelerations on a fixed point in a rotating frame are the gravitational accelerations toward the two bodies and the centrifugal force. The accelerations must sum to zero at some point if it is to remain fixed. The first goal is to find this polynomial. Once you have this polynomial, you can solve it using numerical methods, or you can find an approximate solution.
DH, i just wanted to be a little more anal about this, to include a couple of points that i needed to remember when i did this (for recreational purposes, i don't think i ever needed to do this for a class).
of the two massive objects. ignoring any masses of anything that might be living at the L2 point, we can easily model the two planets as point masses revolving around their common center of mass. and we don't have to think about them being affected by the test mass at L2.
the other thing i needed, but had to remember to something i only used in freshman physics or in my Statics and Dynamics class required for engineering was D'Alembert's principle. this centrifugal force is a fictitious force that we put in because of this.
i think you can get an closed form solution, no? the order of the polynomial doesn't exceed 3, does it?
i think the L4 and L5 points are the cool ones. those are the ones that are "pits" or "depressions" at a local minimum of potential energy
The equation for the L2 point is
[tex]\frac{G(M+m)}{R^3}\left(R\frac{M}{M+m}+r\right)\,-\,\frac{GM}{(R+r)^2}\,-\,\frac {Gm}{r^2}= 0[/tex]
where M and m are the masses of the two massive objects (M > m), R is the distance between the two massive objects, and r, the unknown quantity, is the distance between the smaller object and the L2 point. Denoting α=m/M, x=r/R, this becomes
[tex](1+\alpha)x+1-\frac{1}{(1+x)^2}-\frac {\alpha}{x^2}= 0[/tex]
Clearing the fraction leads to
[tex]((1+\alpha)x+1)x^2(1+x)^2-x^2-\alpha(1+x)^2 = 0[/tex]
which is a fifth order polynomial.
If this is the case, the above polynomial becomes r = -R/2 if you use (r/R)^2 = approximately zero. But the solution to this question is, I believe, r = R(m/3M)^(1/3). Am I missing something here?
[itex]r=R\,(m/3M)^{1/3}[/itex] is an approximate solution. How to get there from the fifth degree polynomial:
First rewrite the polynomial this way:
[tex]x^2((1+x)^3-1) -\alpha(1+x)^2(1-x^3)= 0[/tex]
Expanding the first term,
[tex]x^3(3+3x+x^2) -\alpha(1+x)^2(1-x^3)= 0[/tex]
Assuming [itex]x\ll 1[/itex], [itex]3+3x+x^2\approx 3[/itex] and [itex](1+x)^2(1-x^3)\approx 1[/tex], so<br /> <br /> [tex]3x^3 \approx \alpha[/tex]<br /> <br /> or<br /> <br /> [tex]x\approx\left(\frac{\alpha}3\right)^{1/3}[/tex][/itex]
[itex] <br /> Thanks for your help. But I still not comprehend the last approximation method part. How come x^3 still survives when the other terms vanish?[/itex]
Dropping the x2 and higher power terms from the original polynomial leads to [itex]\alpha(1+2x) \approx 0[/itex], which means [itex]x \approx -1/2[/itex] or [itex]\alpha \approx 0[/itex] (or both). The former is nonsense and the latter is just a reconfirmation of the assumption [itex]\alpha \ll 1[/itex]. In other words, the naive first-order approximation doesn't work. Refactoring the polynomial as a polynomial in [itex]alpha[/itex] and then eliminating higher order terms in x in each term does work.
  • · Replies 16 ·
  • · Replies 86 ·
9K
