Mysterious Increase in Methane Levels Baffles Scientists
The discussion revolves around a recent global increase in methane levels, which has surprised scientists and raised questions about the sources of this greenhouse gas. Participants explore the implications of this increase, its potential natural cycles, and the role of human activity in methane emissions, touching on theoretical and empirical aspects of greenhouse gas effects.
  • Some participants note that the simultaneous rise in methane levels contradicts theories attributing increases primarily to human activity, suggesting a possible natural cycle instead.
  • There is a discussion about the relative greenhouse effects of methane compared to carbon dioxide, with some arguing that the 25x figure for methane's potency may be misinterpreted or misapplied.
  • One participant asserts that methane's absorption capacity is about 3x that of CO2, but highlights the potential for increased methane emissions from natural sources like wetlands.
  • Another participant references past discussions about the greenhouse effects of CO2 and methane, suggesting that the commonly cited potency ratios may depend on specific conditions and concentrations.
  • Concerns are raised about the origins of the 25x figure, with suggestions that it may stem from models that do not accurately reflect the complexities of greenhouse gas interactions.
  • One participant mentions the historical context of methane isotopes in ice cores, implying that there are additional factors influencing methane levels that are not fully understood.
Participants express differing views on the sources of methane emissions and the validity of the 25x potency claim. There is no consensus on the implications of the recent methane increase or the interpretation of its causes.
Participants highlight the complexity of greenhouse gas interactions and the potential for misunderstanding regarding the effects of methane versus carbon dioxide. The discussion reflects ongoing uncertainties in the scientific community about the sources and impacts of methane emissions.
Andre
http://www.tgdaily.com/html_tmp/content-view-39973-113.html
Scientists at MIT have recorded a nearly simultaneous world-wide increase in methane levels. This is the first increase in ten years, and what baffles science is that this data contradicts theories stating man is the primary source of increase for this greenhouse gas. It takes about one full year for gases generated in the highly industrial northern hemisphere to cycle through and reach the southern hemisphere. However, since all worldwide levels rose simultaneously throughout the same year, it is now believed this may be part of a natural cycle in mother nature - and not the direct result of man's contributions.
Also notice the stubborn misunderstanding:
Methane accounts for roughly one-fifth of greenhouse gases in the atmosphere, though its effect is 25x greater than that of carbon dioxide.
Run http://geosci.uchicago.edu/~archer/cgimodels/radiation.html with the basic inputs to get an output radiation of 287.844 W/m2. Now put zero in the CO2 box to get 318.396 W/m2, then restore 375 ppmv for CO2 and run with CH4 put at zero: 289.696. So that's rather more than 30 W/m2 versus less than 2 W/m2, demonstrating that it's rather irrelevant, assuming that the MODTRAN algorithm is correct.
Depends if they mean the total effect of all the methane is 25x the total effect of all the CO2 or they mean a molecule of CH4 has 25x the effect of a molecule of CO2.
Methane is still an effect of human climate change - turning forests into cattle ranches isn't the cow's fault.
No I ran a thread about that long time ago. On equal terms at the same concentrations, CO2 is 5-2 times stronger than methane. The number of 22x or 25x or something is only possible if you'd increase both at the current concentration with one ppmv hence the CO2 from 375 to 376 ppm and methane from 1.7 to 2.7 ppmv but then you're talking about 25 times nothing.
Methane only has about 3x the absorption of CO2 but there is a lot more of it potentially around if bogs/wetlands die off or hydrates evaporate due to temperature rises.
I suspect the 25x number came from some model of all these sources and has become a factoid that gets quoted without understanding what it means.
I thought the object was to nasrty man made evil chemical industrial methane - as opposed to natural cows / wetlands / 'natural so not our fault' methane emissions.
I made these MODTRAN runs a few years ago
showing the difference between methane and carbon dioxide greenhouse effect according to MODTRAN, using the thermal equilibrium principle to convert the delta radiation to temperature effect. This should show that methane is non sequitur
The methane myth was born when the isotope spikes of the Greenland ice cores showed a strong correlation with the isotopes (alleged temperatures) as can be seen here
http://www.ncdc.noaa.gov/paleo/pubs/flueckiger2004/fig9.gif
Obviously with the physics not matching, there must be other factors playing a role.
29K
  • · Replies 59 ·
13K
  • · Replies 17 ·
