Heat gain or loss by s conductor and an insulator.
This discussion focuses on conducting an experiment to compare heat gain or loss between a conductor and an insulator. The proposed method involves boiling a conductor in water until it reaches thermal equilibrium at approximately 100°C, then transferring it to room temperature water to measure temperature changes over time. The heat lost by the conductor is calculated based on the temperature change in the water, utilizing the specific heat of water for accurate measurements. The same procedure is suggested for an insulator of similar dimensions to facilitate a direct comparison of results.
  • Understanding of thermal equilibrium
  • Knowledge of specific heat capacity
  • Familiarity with experimental measurement techniques
  • Basic principles of heat transfer
  • Research methods for measuring specific heat capacity of materials
  • Explore thermal conductivity differences between conductors and insulators
  • Learn about data analysis techniques for temperature change over time
  • Investigate variations in experimental design for heat transfer experiments
Students in physics or engineering, educators conducting heat transfer experiments, and researchers interested in material properties related to thermal dynamics.
firemama
Does anyone know of an experiment or know where I can find an experiment to compare the heat gain or heat loss by a conductor and an insulator?
I'm not 100% sure that this would do the trick, but off the top of my head you could boil a conductor in water log enough for it to reach thermal equilibrium (so that it's temp will be ~100C throughout) ad then quickly transfer it into a container of room temperature water and take measurements of the water's temp as a function of time. The heat lost by the conductor will approximately equal the heat gained by the water and since you know the specific heat of water, you can calculate how much heat is lost as a function of time based on your temperature measurements. Then simply repeat the process with an insulator of similar dimensions and compare your results.
  • · Replies 17 ·
  • · Replies 16 ·
  • · Replies 27 ·
  • · Replies 27 ·
