Auxiallry Field in a Coaxial Cable
The problem involves analyzing the magnetic field in a coaxial cable consisting of two cylindrical conductors with a current flowing through them. The task includes finding the magnetic field in the region between the tubes and calculating the magnetization and bound currents.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the application of Ampere's Law and the evaluation of integrals around circular loops to find the magnetic field. There are questions about the correct setup of the integral and the interpretation of variables involved.
Some participants have provided guidance on evaluating integrals and clarifying the roles of different variables. There is an ongoing exploration of the relationships between the magnetic field, current, and the geometry of the problem, with no explicit consensus reached yet.
Participants are navigating through the implications of cylindrical symmetry and the direction of the magnetic field and current. There is a focus on ensuring clarity in the definitions and relationships of the quantities involved, particularly in the context of the coaxial cable setup.
TFM
A coaxial cable consists of two very long cylindrical tubes, separated by linear insulating material of magnetic susceptibility χm (see Figure). A current I flows down the inner conductor and returns along the outer one, in each case the current distributes itself uniformly over the surface.
a)
Find the magnetic field in the region between the tubes.
b)
As a check, calculate the magnetization and the (surface and volume) bound currents. Confirm that (together with, of course, the free current) they generate the correct magnetic field.
Just Section A at the moment:
I have a feeling that these equations are useful (hinted in a similar question in textbook)
[tex]\oint H .dl =I_{f_encl}[/tex]
[tex]B = \mu H[/tex]
[tex]\mu = \mu_0(1+\chi_m)[/tex]
[tex]B = \mu_0(1+\chi_m)H[/tex]
Does this look okay, what could be a good thing to do next?
TFM
You can use the integral expression you wrote to find H. Evaluate the integral around a circular loop.
Once you have H, your final expression can be used to get B.
So:
I think I am doing the wrong integral, but would it be
[tex]H \pi^2 =I_{f_encl}[/tex]
Or would this be for dA?
TFM
No, not sure where you are getting pi^2 from.
The integral is evaluated going around the circumference of a circle.
I meant for that to be pi r squared, that's an area integral.
So would it be:
[tex]H 2 \pi r = I_{f_{encl}}[/tex]
TFM
Yes. So B = ?
So:
which rearranges to give H:
[tex]H = \frac{I_{f_{encl}}}{2\pi r}[/tex]
and since:
B equals:
[tex]B = \mu_0(1+\chi_m)(\frac{I_{f_{encl}}}{2\pi r})[/tex]
B equals:
[tex]B = \mu_0(1+\chi_m)(\frac{I_{f_{encl}}}{2\pi r})[/tex]Does this look correct?
TFM
Excellent, thanks.
So for part B,
Question
Useful Equations:
Magnetization Equation:
[tex]M = nm[/tex]
Surface bound current Equation:
[tex]j_{ind} = M x \hat{S}[/tex]
Volume bound Current Equation:
[tex]J_{ind} = \nabla x M[/tex]
Edit These twi above equations should be curl, not x
I am not sure if these are the right equations to use, though?
Where would be the best place to start?
TFM
I have a feeling that this equation is very useful for the second part:
[tex]M = \chi_M H[/tex]
where M is the Magnetization
Since we have worked out H to be:
Is thuis a useful equation?
TFM
So for this question, would the equation for magnetization be:
[tex]M = \chi_M (\frac{I_{f_{encl}}}{2\pi r})[/tex]
does this look right?
thus would the surface bound current be:
[tex]j_{ind} = \chi_M (\frac{I_{f_{encl}}}{2\pi r}) \times \hat{S}[/tex]
And the Volume bound current:
[tex]J_{ind} = \nabla \times (\chi_M (\frac{I_{f_{encl}}}{2\pi r}))[/tex]
Is this right? If so, what might be the next logical step?
TFM
It has been a while since I worked on this stuff, so I don't know about part (b). Maybe somebody else can help out here?
Hmmm... I think you'd better go back to part (a) for a moment, before I can help you through part (b) :
Let's make it a little more obvious which quantities are vectors and which are scalars; and what exactly you are integrating over...Ampere's Law for the Auxiliary Field [itex]\vec{H}[/itex] is:
[tex]\int_{\mathcal{P}} \vec{H} \cdot \vec{dl}=I_{f_{enc}}[/itex]<br /> <br /> Where [itex]\mathcal{P}[/itex] is an Amperian loop. While you seem to (thanks to RedBelly's assistance) have chosen the correct Amperian loop, you have neglected to explicitly state your choice and justify it's usefulness...<b>Hint:</b> How does the cylindrical symmetry in this problem help you here? Which direction must [itex]\vec{H}[/itex] point in?<br /> <br /> Once you have explicitly stated what your Amperian loop is, you should be able to explicitly determine the amount of free current enclosed in it, [itex]I_{f_{enc}}[/itex] in terms of the [itex]I[/itex] given in the problem.[/tex]
Where [tex]{P}[/tex] is an Amperian loop. While you seem to (thanks to RedBelly's assistance) have chosen the correct Amperian loop, you have neglected to explicitly state your choice and justify it's usefulness...Hint: How does the cylindrical symmetry in this problem help you here? Which direction must [tex]\vec{H}[/tex] point in?
Well the Magnetic field will decrease in strength the further from the wire you get.
the [tex]\vec{H}[/tex] Should point in the direction of be radially outwards using right hand rule on diagram?
TFM
No, [itex]\vec{H}[/itex] is not radially outwards...what are the free currents in this problem, and which direction do they point? Point your thumb in the direction of the current and your fingers will curl in the direction of the field...are you familiar with cylindrical coordinates [itex]s[/itex],[itex]\phi[/itex] and [itex]z[/itex]? If you orient your coordinate system so that the axis of the cylinder is along the z-axis ([itex]\hat{z}[/itex] direction), then what direction does that give you for [itex]\vec{H}[/itex]?
The free current is the current traveling in the wire. it is going upwards in the inner wire, and downwards in the outer cylinder/cable
I am slightly confused by:
Point your thumb in the direction of the current and your fingers will curl in the direction of the current
If your thumb points in the direction of the current, how can the curl of your fingers also be the current?
TFM
Sorry, that was a typo; the second "current" was supposed to be "field"...I've edited my post.
...In terms of the cylindrical unit vectors, [itex]\hat{s}[/itex],[itex]\hat{\phi}[/itex] and [itex]\hat{z}[/itex], which direction do the currents flow (Don't worry about whether they flow in the positive or negative direction)?
Judging by this the field is flowing in circles, so in terms of cylindrical coordinates, it must be:
[tex]\hat{\phi}[/tex]
TFM
Yes, now what is the direction of [itex]\vec{dl}[/itex] If you choose a coaxial circle as your Amperian loop?
Would it be:
[tex]\hat{s}[/tex]
Since it is for a circle of radius r through a full 360 degrees?
TFM
If it were [itex]\hat{s}[/itex], then that would mean that as you went around the loop, for a small change in the magnitude [itex]|\vec{dl}|[/itex] , [itex]s[/itex] (or [itex]r[/itex] as you have it written) would change by an amount [itex]|\vec{dl}|[/itex] (Since that change would be in the [itex]\hat{s}[/itex] direction)...Does that sound right for a circle of constant radius [itex]s[/itex]?
No it doesn't, it must be:
TFM
Yes, Good! ...so what is the dot product [itex]\vec{H} \cdot \vec{dl}[/itex]?
Would it be
[tex]H\hat{\phi}[/tex]
TFM
Well, [tex]\vec{H}=H\hat{\phi}[/tex] and [tex]\vec{dl}=dl\hat{\phi}[/tex], so [tex]\vec{H} \cdot \vec{dl}=Hdl (\hat{\phi} \cdot \hat{\phi})[/tex]
What is the dot product of the unit vectors [tex]\hat{\phi} \cdot \hat{\phi}[/tex]?
Would that be 1?
TFM
Yes, since after all; they are unit vectors...What does that make [itex]\vec{H} \cdot \vec{dl}[/itex]?
Since:
and
Would that make
[tex]\vec{H} \cdot \vec{dl}[/tex]
1?
TFM
Nope,
[tex] \vec{H} \cdot \vec{dl}=Hdl (\hat{\phi} \cdot \hat{\phi})=Hdl *(1)=Hdl[/tex]
Now what about the magnitude of [itex]|\vec{dl}|=dl[/itex]...what is that for the circle? (remember, the only quantity that changes along the path is [itex]\phi[/itex])
Would this be:
[tex]\hat{s}[/tex]
Since the magnitude will decrease the further out you get from the current?
TFM
  • · Replies 16 ·
  • · Replies 26 ·
  • · Replies 23 ·
