| Thread Closed |
Curve sketching |
Share Thread | Thread Tools |
| Nov1-08, 01:21 PM | #1 |
Curve sketching
Find the image set of fucntion fx = (2x^2 + 2x + 1)/(x^2 + x - 1 ) The attempt at a solution 1. multiply the denominator with y and then assume x is real i get (y-2)^2 - 4(y - 2)(-y-1) => 0 5y^2 - 8y - 4 => 0 y = 2 and y = -2/5 But the answer is y => 2 and y =< 2/5 not -2/5 Then i substitute the -2/5 to the original equation and i got complex solution. So is it mean that -2/5 is out. And 2nd, why the answer is 2/5? And 3rd, how to test the validity of the range like whether it is a<y<b or y < a , y> a? I sketched using tools on http://graph.seriesmathstudy.com/ and -2/5 is valid asymptote. |
| Nov1-08, 02:14 PM | #2 |
Mentor
How did you get this? Also, you shouldn't use => when you mean =. (y-2)^2 - 4(y - 2)(-y-1) => 0 I don't see any connection between it and what you started with. Use = for expressions that are equal, not =>, which is used when one equation implies another.
| Nov1-08, 02:49 PM | #3 |
It's not x = -2/5 but it's y = -2/5. And => is more 'than or equal' and otherwise. Let me show you my work
First I rearrange this into like this from y = (2x^2 + 2x + 1)/(x^2 + x - 1 ) into y(x^2 + x - 1 ) - (2x^2 + 2x + 1) = 0. Then i use b^2 - 4ac => 0 and compare the coefficient from (y-2)x^2 + (y-2)x + (-y-1) = 0 which gives (y-2)^2 - 4(y-2)(-y-1) => 0. After factoring it, i get y = 2 and y = -2/5. You can try use the http://graph.seriesmathstudy.com/ and see that there is at least 2 horizontal asymptote there. My question is if i substitute the value of y to the original equation (to y not x) I will get complex solution and 2nd the answer to the question are 2 and 2/5. And the more i think about this question the more confuse i am. Can some explain to me how to determine the validity of range like whether the solution is a < fx < b or fx > b, fx < b? |
| Nov2-08, 01:42 AM | #4 |
Mentor
Curve sketchingNow that I've seen your work I am able to follow your reasoning. In the discriminant (b^2 - 4ac), what you have found are two values of y that make the discriminant 0, namely y = 2 and y = -2/5. If the discriminant is zero, that means you'll have only one solution for x, namely (-y + 2) / (2(y -2)). If y = 2, x is undefined, since both numerator and denominator are zero. If y = -2/5, x = -1/2. What this means is that you have done a whole lot of work just to find one point on the graph of this function. There are some fairly simple things you can do to find out what the graph of this function looks like, as I've already stated and will put here again.
I have drawn a rough graph of this function. To the left of the vertical line x [tex]\approx[/tex] -1.62, the graph is always above the line y = 2, approaching it from above as x gets more and more negative. As x approaches -1.62 from the left, the y values get larger and larger. Between approximately -1.62 and .62, the y values are all negative and approach neg. infinity as x approaches -1.62 from the right and as x approaches .62 from the left. If x is larger than .62, the y values are all larger than 2, with y approaching infinity as x approaches .62 from the right. As x gets larger and larger, y approaches 2 from above. |
| Nov2-08, 05:20 AM | #5 |
As i mentioned before, the inner range is probably -2/5 because you can just factorize the y from (y-2)x^2 + (y-2)x + (-y-1) >= 0 where you will get 2 and -2/5 as you already prove the 2. Calculus will only make the function harder. My question is if i substitute -2/5 into the original equation, i will get complex solution. 1st Let y = 2; 2(x^2 + x - 1 ) - (2x^2 + 2x + 1) = 0, -3 = 0 which is not true. Therefore the fx will never pass through 2. 2nd Let y = -2/5, you will get the complex solution. Now I don't know if this just an error from book or not but, the answer is fx>2 and fx < 2/5. not -2/5 |
| Nov2-08, 11:17 AM | #6 |
Mentor
If you do know some calculus, you could find f'(x) and see where it is zero. That would give you the x-value at the top of the middle section of the graph. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Curve sketching
| Curve sketching | Precalculus Mathematics Homework | 11 | ||
| Curve Sketching | Calculus & Beyond Homework | 2 | ||
| Curve Sketching | General Math | 4 | ||
| Curve Sketching | Precalculus Mathematics Homework | 13 | ||
| Curve Sketching | Introductory Physics Homework | 2 | ||
