Triple integral finding bounds?
The discussion focuses on finding the bounds for a triple integral over a solid defined by a cone and a sphere, with specific points P=(0,0,5), Q=(0,4,3), and R=(sqrt(6),sqrt(10),0). The participants clarify that the planes perpendicular to the x-y plane refer to the y-z plane and the vertical plane through point R. To solve the integral, it is recommended to divide the solid into horizontal slices of thickness dz and integrate over z, treating the sections below and above point Q separately.
  • Understanding of triple integrals in multivariable calculus
  • Familiarity with the geometric properties of cones and spheres
  • Knowledge of coordinate systems, particularly Cartesian and spherical coordinates
  • Ability to visualize and interpret solid regions in three-dimensional space
  • Study the method of slicing solids for triple integrals
  • Learn about spherical coordinates and their application in integration
  • Explore the concept of integrating over regions defined by multiple surfaces
  • Review examples of triple integrals involving cones and spheres
Students and educators in calculus, particularly those focusing on multivariable integration, as well as anyone involved in geometric analysis of solids in three-dimensional space.
beallio
Integrate the function over the solid given by the figure below (the bounding shapes are planes perpendicular to the x-y plane, a cone centered about the positive z-axis with vertex at the origin, and a sphere centered at the origin), if P=(0,0,5),Q=(0,4,3), and R=(sqrt(6),sqrt(10),0) .
https://instruct.math.lsa.umich.edu/webwork2_course_files/ma215-f08/tmp/gif/homework8b-prob1-pimages/sfig16-8-1g4.gif
planes perpendicular to the x-y plane are the x-z plane and the y-z plane
how do you use the figure to get the bounds for x,y,z
I think that x is from 0 to R
then y is from 0 to 4
and z is from 0 to 5
is this correct? do I need to switch to spirical coordinates?
Welcome to PF!
Hi beallio! Welcome to PF! :smile:
No, "planes perpendicular to the x-y plane" means the y-z plane and the vertical plane through R.
The top surface is part of a sphere, and the "front surface" is also curved … it's the cone through Q.
Hint: divide the solid into horizontal slices of thickness dz, and integrate over z (split the integration into two parts … one below Q, and one above Q, since they'll be different functions). :wink:
