Calculating Potential Between Conducting Shells
  • Thread starter Thread starter LocationX
    Conducting
The discussion revolves around calculating the electric potential between two conducting shells, one with an inner radius R1 and an outer radius R2. The problem involves understanding the distribution of charges Q1 and Q2 on the respective surfaces and how these affect the potential in different regions, particularly between the shells and inside the inner shell.
  • Mixed
  • Participants explore the use of Gauss' Law to calculate electric fields and potentials, questioning how to account for grounded surfaces and the implications of charge distributions.
The discussion is active, with various interpretations of the problem being explored. Some participants suggest using superposition principles, while others question the relationships between the charges and the implications of grounding. There is no explicit consensus on the correct approach or interpretation of the problem.
Participants note the importance of charge distributions and the grounding condition of the outer shell, which complicates the potential calculations. There is also confusion regarding the assumptions about the thickness of the shells and how that affects the electric field and potential in different regions.
LocationX
A spherical conducting shell has an inner radius R1 and outer radius R2
There is a charge Q1 spread uniformly on the inner radius
THere is a charge Q2 spread uniformly on the outer radius
what is the potential for a distance R1<r<R2?
What is the potential for a distance r<R1?
Since the potential is continuous between surfaces, the potential the outer surface and inner surface must be equal at the boundary
I'm not sure where to begin with this question. I was thinking about treating the surfaces as point charges but we can't do that in this case since we want to know the potential between the shells. Any advice?
My advice is to exploit the spherical symmetry in the problem, by using Gauss' Law to calculate the electric field and then integrating it to find the potential.
i forgot to mention that the potential on R2 is grounded
the potential inside r<R1 should be [tex]V=\frac{KQ_1}{R_1}[/tex] since the potential inside should equal the potential at the surface.
The potential at R2 is zero, but must increase to [tex]V=\frac{KQ_1}{R_1}[/tex] at R2 right?
Assuming you meant to say that V goes from zero at R2 to [tex] V=\frac{KQ_1}{R_1}[/tex] at R1, then yes...but to determine the functional relationship of how V increases in this region, you will need to use gauss' law
i'm not sure how to take into account that V=0 at R2
[tex]V=-\int_{R_1}^r \frac{kQ_1}{r^2} = kQ_1 \left( \frac{1}{r} - \frac{1}{R_1} \right)[/tex]
What you've computed is the potential due to just the inner shell of charge, not the potential due to the total charge configuration...you can find that by using the superposition principle...what is the potential at r due to the outer shell of charge?
potential due to the other shell is zero isn't it?
if we just looked at the outer shell, E=0 inside the shell and since the potential at the outer shell is zero, then the potential inside the shell should be zero as well.
don't forget induced charges...
E is zero inside the shell, but the potential isn't: Remember, [itex]V_{total}(R_2)=0[/itex] while [itex]V_{duetoQ_1}(R_2)=kQ_1 \left( \frac{1}{R_2} - \frac{1}{R_1} \right)[/itex] and so [itex]V_{duetoQ_2}(R_2)=V_{total}(R_2)-V_{duetoQ_1}(R_2) \neq 0[/itex]. [itex]V_{duetoQ_2}(r)[/itex] will be constant, since E=0 inside the outer shell, but it will not be zero.
There is no need to consider induced charges here, since the charge density on all surfaces in the problem is specified.
so the potential is be:
[tex] V(R_2)=-kQ_1 \left( \frac{1}{R_2} - \frac{1}{R_1} \right)[/tex] [tex] V= kQ_1 \left( \frac{1}{r} - \frac{1}{R_1} -\frac{1}{R_2} + \frac{1}{R_1} \right) [/tex]
[tex] V=kQ_1 \left( \frac{1}{r} - \frac{1}{R_2} \right)[/tex]
the potential doesn't depend on Q2?
it's also curious that there IS potential on the outer shell we it is grounded (to cancel out the potential from the inner shell)
Your result is correct...V(r) does not depend on [itex]Q_2[/itex] in the region [itex]R_1<r<R_2[/itex]...outside the outer shell however it would depend on Q2.
so the total potential at the outer shell is zero, but in order for this to happen, there must be a potential on the outer shell to cancel the inner shell?
is Q1 and Q2 related in any way?
should the two be the same?
Just Q1=-Q2 (inside)
so the E field seen from the outside is just kQ1/r^2?
Q1 and Q2 do not need to be related in any way.
The total potential at R2 must be zero, and given that the potential at R2 due to the inner shell is non-zero, the potential due to the outer shell must also be nonzero at R2 in order for the two to cancel each other out.
The Efield due to the inner shell is kQ1/r^2 for r>R2 but the total E-field at r>R2 is k(Q1+Q2)/r^2...(or were you asking about the region R1<r<R2?)
i'm not sure i follow, here's what I'm thinking
the inner shell has a charge of Q1 on the outside
so similar to image charges, wouldn't the grounded shell have a charge -Q1 on the inside (and +Q1 on the outside) so when seen from r>R2, it's as if there was just a point charge of Q1 at the origin since the outer shell is grounded and the inner shell is charged.
Hmmm.. I seem to have misread the original problem:
There is only a single shell in this problem. It is a conductor, so the field in the region R1<r<R2 must be zero and the potential must be constant in this region! Moreover, Q1 must be zero (as a quick application of Gauss' law shows that E=kQ1/r^2 but E=0)!
Also the field inside r<R1 is zero, so the potential in that region is constant too!
The potential must be continuous everywhere, if the outer surface is grounded, then V(R2)=0, and hence V(r)=0 for [itex]r \leq R2[/itex]
The field outside is due entirely to Q2 since Q1 is zero.
oh, I'm still confused about when there are two shells (the problem we were answering before)
was what i wrote above true? Because i don't see how the total E-field at r>R2 is k(Q1+Q2)/r^2
If the shells are assumed to be very thin, then they are treated as each having a single surface rather than an inner and an outer surface for each shell...that is what I had originally thought the problem was.
If you want two shells of finite thickness, you need to say whether Q1 is on the inner or outer surface of the shell, and similarly for the outer shell and Q2. You also need to specify the thickness of each shell.
edit- or are you thinking of the case where Q1 is the net charge of the inner shell and similarly for the outer shell?
right, for the problem with two very thin shells, the result that was derived was correct:
V=kQ1/R1 for r<R1
and
V=kQ1(1/r - 1/R2) for R2>r>R1
but I'm saying that E for r>R2 is kQ1/r^2 and not k(Q1+Q2)/r^2
going by the reasoning that:
is this valid?
No, the outer shell has charge Q2.
There is no "inner" or "outer" surface of the R2 shell, since it is assumed to be "very thin".If you instead looked at a shell of finite thickness, then yes a charge of -Q1 would have to be induced on its inner surface, but(!) if its net charge is given as Q2, then the charge on its outer surface would have to be Q1+Q2 not just Q1 (unless Q2=0 i.e. for a neutral outer shell)
i'm confused because i thought the plate was grounded, wouldn't all the extra charge just end up going off the shell?
Not necessarily, "grounded" really just means that you are defining the potential there to be zero. Since the potential is only unique up to a constant, this amounts to choosing a value of the constant that makes the potential at that spot zero. It doesn't necessarily mean that there will be no charge on the shell.
If however, the "grounding" is achieved by connecting the shell to some large body like the earth, which would otherwise be at a lower potential, then charge would move through this connection to the earth. And the net charge on the shell would be zero.
then Q2 must depend on Q1. If we were to add more charge to the inner sphere, then the outer sphere would have to increase to balance out Q1 right?
another point, Q2 should be negative if Q1 was positive right?
Why do you keep trying to assert that there is a relationship between Q1 and Q2?
Is Q2 the net charge on the conductor? Or something else?
Are you talking about the case where the outer shell has a finite thickness or the case when it is "very thin"?
the very thin case.
Suppose there are two neutral shells.
Charge in placed on the inner shell. Then you're saying since there is no dependence, the outer shell would stay neutral? then Q2=0?
You also need to tell me how the outer shell is grounded:
If it is simply defined to be at V=0 before you add the charge, then Q2 will be independent of Q1 since V is free to change and will no longer be zero after the charge is added.
On the other hand, if the outer shell is grounded by some physical means (like a wire connecting it to the Earth) such that after the charge is added to the inner shell, V is still zero on the outer shell, then Q2 will have to change.
Considering the first case (not grounded to earth), if charge was added to the inner shell, then the field would be V=kQ1/r^2 for any r>R2? since there is ONLY charge on the inner shell and the outer shell has no were to gain additional charge. Thus, Q=0 for the outer shell? Or would this create some sort of image charge?
Considering the second case (grounded to earth), if we were to place charge on the inner shell, then for the outer shell to still have V=0, there must be an addition of charges onto the outer shell in order for it's potential to be zero at the surface right?
Then the field for r>R2 is k(Q1+Q2)/r^2
does this work?
Yes, that works fine.
In the first scenario, Q2=0 both before and after the charge is added to the inner shell. Since V(R2) is free to change, it is initially zero and it is kQ1/(R2) after. There will be no induced charge on the outer shell, since it is "very thin".
In the second scenario, V(R2)=0 both before and after, so there must be a charge -q induced when you add charge q to the inner shell.
since the entire thing is ground (to earth), if we placed charge on the shell, wouldn't it just go to the earth? so Q2=0
Some of it will, but there will have to be an induced charge of -Q1 still on it so that the potential is actually zero...But(!) this is IF it is grounded by a physical means like a wire connecting it to the Earth.
If instead it were just defined to be at V=0, it wouldn't matter what Q2 was, but it would mean that Q1 would have to be zero.
  • · Replies 19 ·
  • · Replies 19 ·
