Calculating Hall Voltage with Given Values | Electromagnetism Problem"
  • Thread starter Thread starter jaejoon89
    Voltage
The Hall voltage for the given parameters is calculated using the formula V_H = (IBd) / (nqA). With a magnetic field (B) of 2.5 T, current (I) of 15 A, charge (q) of 1.6 x 10^-19 C, and electron density (n) of 8.47 x 10^22 electrons/cm^3, the calculated Hall voltage is approximately 1.3 µV. The dimensions of the slab are 0.20 cm thick and 1.5 cm wide, leading to a cross-sectional area (A) of 0.0003 m². The calculated value does not match any of the multiple-choice answers provided, indicating a potential error in the calculations or assumptions made.
  • Understanding of Hall effect principles
  • Familiarity with electromagnetism equations
  • Knowledge of charge carrier density calculations
  • Ability to perform unit conversions (cm³ to m³)
  • Review the Hall effect and its applications in electromagnetism
  • Learn about charge carrier density and its impact on Hall voltage
  • Explore the effects of varying magnetic field strengths on Hall voltage
  • Investigate common errors in electromagnetism calculations
Students studying electromagnetism, physics educators, and anyone involved in experimental physics or electrical engineering who seeks to understand Hall voltage calculations.
jaejoon89
What is the Hall voltage? B = 2.5 T, I = 15 A, q = 1.6*10^-19 C, n = 8.47*10^22 electrons/cm^3. B is going through a square slab 0.20 cm x 1.5 cm (B going through 0.20 cm thick part... not sure which one though counts as the width)
V_H = v_d * B * w where w is width
v_d = I/(nqA)
Thus,
V = (IBd) / (nqA)
V = (15 A * 2.5 T * 0.015 m) / ((8.47*10^22 electrons/cm^3)*(1*10^6 cm^3 / m^3)*(1.6*10^-19 C)*(0.015 m * 0.0020 m) = 1.3*10^-6V
It is multiple choice and the answers are 2.6 V, 1.9 mV, 3.6 micro V, 4.2 mV, or none of them. I am leaning towards none of the above but it usually is pretty rare for one of these questions so I suspect there's an error in my calculations...
I get about same answer, 1.4 micro V
  • · Replies 19 ·
  • · Replies 26 ·
