Buoyancy without density of fluid
The discussion centers on calculating the tension in a string supporting a submerged ball of mass m_b and volume V in a fluid of density rho_f. The tension T is derived from the equation T = mg - rho_f * V * g, where mg represents the weight of the ball and rho_f * V * g represents the buoyant force. Participants emphasize that the fluid density rho_f is essential for accurately determining the buoyant force, as changing the fluid affects the tension in the string. The conclusion is that rho_f cannot be disregarded when calculating buoyancy in this context.
  • Understanding of Newton's laws of motion
  • Familiarity with buoyancy principles
  • Knowledge of fluid density concepts
  • Basic grasp of algebraic manipulation in physics equations
  • Study Archimedes' principle and its applications in fluid mechanics
  • Learn about the relationship between fluid density and buoyant force
  • Explore the effects of different fluids on buoyancy calculations
  • Investigate the role of tension in various physical systems involving submerged objects
Students studying physics, educators teaching fluid mechanics, and anyone interested in understanding the principles of buoyancy and tension in submerged objects.
Vanessa23
A ball of mass m_b and volume V is lowered on a string into a fluid of density rho_f. Assume that the object would sink to the bottom if it were not supported by the string.
What is the tension T in the string when the ball is fully submerged but not touching the bottom?
It claims that rho_f is not needed in the part representing buoyancy
I think it should be:
T=Fg - B
where T is the force of tension and B is the buoyancy force.
Fg=rho(object)*V*g
B=rho_f*V*g
therefore, T=mg - rho_f*V*g
how can you not use rho_f in calculating the buoyancy force?
You need the density, unles you are going to quote the answer in terms of density.
Imagine the fluid is air and a metal ball, if you change the fluid to water - then the tension in the string is going to change.
11K
  • · Replies 21 ·
