Finding Drag w/ acceleration & Boyant force
The discussion revolves around a physics problem involving a speed boat that is accelerating while experiencing buoyant force and thrust. The participants are tasked with determining the drag force acting on the boat.
  • Exploratory, Problem interpretation, Assumption checking
  • Participants discuss the relationship between buoyant force, gravitational force, and acceleration. They explore the net force acting on the boat and question how to set up the equations correctly. There is confusion regarding the calculation of forces and the interpretation of the net force equation.
Some participants have provided guidance on the algebra involved and the correct setup of the equations. There is an acknowledgment of mistakes in calculations, but no consensus has been reached on the final answer. The discussion remains open with participants seeking clarification on their reasoning.
Participants are working under the constraints of a homework assignment, which may limit the information they can use or the methods they can apply. There is an emphasis on understanding the forces in play and their respective directions.
swede5670
A speed boat is accelerating at 5 m/s/s. If the Boyant force (the force the prevents the boat from sinking) is 3140 N and the thrust that the motor exerts on the boat is 1876 N, what is the drag on the boat (drag in a fluid is a like friction on land).
Fnet = ma
We just started getting 2 part equations and I'm a little confused on what I have to solve for first. Would someone help me figure out what to solve for first?
I was thinking that since the boyant force is 3140N going up then gravity must be pulling 3,140N down right? So then the acceleration downwards is 9.81 m/s/s, so 3,140N = X * 9.81 then divide 3,140 by 9.81 and you get 320.081549kg. Does this help at all?
Fnet = ma
Fnet = (320kg * 5m/s/s)
If that is correct, what do I use for Fnet
Fnet = ma
Fnet = ma
Yes looks good so far. The boat is accelerating in the x direction. The net force is the algebraic sum of the forces acting on the boat in the x direction. What are those forces? (one is given, the other is unknown; you need to solve for it).
1876 N - Ff = (320kg * 5m/s/s)
1876N/(320kg * 5m/s/s) = Ff
1.1725 is the force of friction? I'm pretty sure that's not right, what am I missing?
Your algebra!
1876-Ff = 320(5)
Ff = 1876 - (320)5
Haha thanks a lot, that was a dumb mistake.
I appreciate the help!
  • · Replies 38 ·
  • · Replies 31 ·
  • · Replies 24 ·
  • · Replies 17 ·
