| Thread Closed |
derivation of e |
Share Thread | Thread Tools |
| Nov3-08, 07:29 PM | #1 |
derivation of e
the common derivation of e is pretty straightforward, Lim x->oo (1+1/x)^x, but how does one prove that the infinite sum [tex]\sum[/tex][tex]\frac{1}{j!}[/tex] as j goes from 0 to oo is equal to e?
p.s. how does one use LaTex for the super and subscripts in summation? |
| Nov3-08, 10:20 PM | #2 |
Recognitions:
use taylors theorem to show that e^x equals the limit of its taylor series, in particular for x=1.
| Nov3-08, 10:45 PM | #3 |
And use your "e" definition to prove
IF f(x) = e**x THEN f'(x) = f(x) (your Taylor's expansion needs this result) |
| Nov4-08, 04:12 AM | #4 |
Recognitions:
derivation of e
It can be done more simply.
specialize (1+1/x)^x to a_n=(1=1/n)^n (n a positve integer) and expand with the binomial theorem next show that if b_n=the sum lim sup b_n<=e<=lim inf b_n thus the limit of the sum is e this is done in most calculus books |
| Nov4-08, 08:11 AM | #5 |
sorry to all:
i do not really understand what you are saying. in response to however, i do not get the next part. could someone please explain it? |
| Nov4-08, 08:32 AM | #6 |
does this make sense:
take the taylor series for e^x, at x=1, and you get the sum? since i unfortunately have no experience with Taylor series, what is the proof for e^x. sorry if i seem like i want to prove everything that anyone says, it is just that i do not have a background in the area. |
| Nov4-08, 11:36 AM | #7 |
If y= ex, then ex+h- ex= ex(eh-1). The derivative of ex is
[tex]e^x\lim_{h\rightarrow 0}\frac{e^h-1}{h}[/tex] a constant times ex. What is that constant? Given that [itex]\lim_{x\rightarrow \infty} (1+ 1/x)^x= e[/itex], let h= 1/x. Then h goes to 0 as x goes infinity and [itex]\lim_{h\rightarrow 0} (1+h)^{1/h}= e[/itex]. That means that, for h very close to 0, [itex](1+h)^{1/h}[/itex] is very close to e and so 1+ h is very close to eh. Therefore, eh- 1 is close to h and (eh-1)/h is close to 1: in the limit, [tex]\lim_{h\rightarrow 0}\frac{e^h-1}{h}= 1[/tex] and so the derivative of ex is, again, ex. It follows that all derivatives of ex are ex and, at x= 0, 1. From that it follows that the MacLaurin series for ex is [tex]\sum_{n=0}^\infty \frac{1}{n!} x^n[/tex] and, finally, taking x= 1 that [tex]\sum_{n=0}^\infty \frac{1}{n!}= e^1= e[/tex] I should point out that it is perfectly valid to define exp(x) to be the function satisfying "dy/dx= y with y(0)= 1" and get the derivative immediately. We could also define "ln(x)" to be [tex]\int_0^x \frac{1}{t}dt[/tex] and then define exp(x) as its inverse function (after proving, of course, that has an inverse function). |
| Nov4-08, 11:48 AM | #8 |
Suppose that you can write some function f(x) as a polynomial of infinite degree. [tex]f(x) = a_0 + a_1 x + a_2 x^2 + a_3 x^3 + ... + a_k x^k + ...[/tex] How do you find all the coefficients [tex]a_i[/tex]? Plug in 0, and you get [tex]a_0[/tex]: [tex]f(0) = a_0 + a_1 (0) + a_2 (0)^2 + a_3 (0)^3 + ... = a_0[/tex] What about the rest? Well, take the derivative of f: [tex]f'(x) = a_1 + 2 a_2 x + 3 a_3 x^2 + ... + k a_k x^{k-1} + ...[/tex] Notice that [tex]a_0[/tex] drops out. You can plug in 0 to f' and extract [tex]a_1[/tex]. [tex]f'(0) = a_1 + 2 a_2 (0) + 3 a_3 (0)^2 + ... + k a_k (0)^{k-1} + ... = a_1[/tex] To find [tex]a_2[/tex], you take the derivative again and find f''(0). But be careful this time. Taking the derivative has popped a '2' from the exponent on x and thrown it into your equation. [tex]f''(x) = 2 a_2 + 6 a_3 x + ... + k (k-1) a_k x^{k-2} + ...[/tex] [tex]f''(0) = 2 a_2 + 6 a_3 (0) + ... + k (k-1) a_k (0)^{k-2} + ... = 2 a_2[/tex] So [tex]a_2 = \frac{f''(0)}{2}[/tex]. Continue this process, and you find that [tex]a_k = \frac{ f^{(k)}(0) }{k!}[/tex] (where [tex]f^{(k)}[/tex] is the k-th derivative and k! is k factorial). So for any "well behaved" function f, we have [tex]f(x) = \Sigma_{k=0}^\infty \frac{f^{(k)}(0)} {k!}x^k[/tex]. Now, applying this to [tex]f(x) = e^x[/tex], what do we get? Well, [tex]e^x[/tex] is magical, because no matter how many times you take the derivative, it stays the same. That is, [tex]f^{(k)}(x) = f(x) = e^x[/tex]. And knowing that [tex]e^0 = 1[/tex], we know that [tex]f^{(k)}(0) = f(0) = e^0 = 1[/tex]. So finally, for our grand finale, we have: [tex]e^x = \Sigma_{k=0}^\infty \frac{1} {k!} x^k[/tex]. So if we want to know what the number "e" itself is equal to, we just set x = 1: [tex]e = e^1 = \Sigma_{k=0}^\infty \frac{1} {k!}[/tex]. |
| Nov4-08, 07:04 PM | #9 |
As a side note, there's usually an error term for Taylor expansions, but elementary functions like the exponential, sine and cosine have an infinite radius of convergence so this is disregarded in those cases.
The LaTeX goes \sum_{n = 1}^{\infty} a_{n} to get [itex]\sum_{n = 1}^{\infty} a_{n}[/tex], you might find tutorials somewhere on here or elsewhere! |
| Nov5-08, 06:22 AM | #10 |
Recognitions:
[tex]\sum_{n=0}^{\infty} \frac{x^n}{n!}[/tex]. and we see immediately that it converges for all values of x by the ratio test, and that it fulfills the definitions requirements. |
| Nov5-08, 10:56 AM | #11 |
And it has nothing to do with "elementary" functions. The function ln(x) is as "elementary" as exponential but its Taylor series, around x=1, has radius of convergence 1. |
| Nov5-08, 11:04 AM | #12 |
Recognitions:
(1+1/n)^n by the binomial theorem we have (1+1/n)^n=Σn!/k!/(n-k)!/n^k 1/k! is what we have in the alternate sum so a two part proof would be lim (1+1/n)^n=lim Σn!/k!/(n-k)!/n^k=Σlim n!/k!/(n-k)!/n^k=Σ1/k! lim Σn!/k!/(n-k)!/n^k=Σlim n!/k!/(n-k)!/n^k is the hard part since lim n!/(n-k)!/n^k=1 is obvious we should first show both limits exist next we use a common calculus method to show two number are equal it is often easier to show that they are not unequal for example if we wish to show x=y we might show x<=y y<=x now let {s_i} be the sequence of partial sums of Σ1/k! {t_i} be the sequence of values of (1+1/n)^n with s and t there respective limits (both equal to e in the end) it can be seen that t_i<s_i<=s because the terms in t_i when considered a sum by the binomial theorm a {s_n} is a sequence of partial sums of positive numbers hence increasing terms of t_i are the terms of s_i multiplied by n!/(n-k)!/n^k (are all less than or equal 1) that is {t_i}={(1+1/n)^n}={Σn!/k!/(n-k)!/n^k}=={Σ[n!/(n-k)!/n^k][1/k!]} so t<=s so the harder step will be s<=t suppose we make two approximations one where n>N one where n>M>N the idea is when n is very large early terms of t_n look like terms of s_N and while later terms do not, they do not matter (they are small) s-2eps<s_n-eps<t_n<=t whenever n>M>N so we first estimated t_n<s_N-eps then estimated s_n<s-eps and combined them to get s-2eps<=t hence s<=t hence s=t qed |
| Nov5-08, 06:15 PM | #13 |
I wouldn't consider all elementary functions of course, only those under consideration, which are entire with the Taylor series coinciding with the function at every point. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: derivation of e
| Derivation of E = mc^2 | Special & General Relativity | 24 | ||
| derivation | Introductory Physics Homework | 1 | ||
| Derivation of the SE | Quantum Physics | 29 | ||
| Need help with a derivation | Electrical Engineering | 1 | ||
| derivation | Introductory Physics Homework | 2 | ||
