| Thread Closed |
IUPAC naming rules |
Share Thread | Thread Tools |
| Nov3-08, 08:19 PM | #1 |
IUPAC naming rules
What is the IUPAC name for the following compound. (Benzene with two chlorines sticking out one at Carbon 2 the other at Carbon 5) 2. Relevant equations 3. The attempt at a solution I understand that the compound's name has to be something like 2,5-dichlorobenzene but are the two numbers in front supposed to be 2 and 5 or is the supposed to be a different number. |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Nov3-08, 08:26 PM | #2 |
| Nov3-08, 09:25 PM | #3 |
Recognitions:
The way you describe, you might also say a chlorine is at carbon 1 and at carbon 2. My guess, if this numbering is acceptable, is "1,2-dichlorobenzene". An alternative name may actually be better accepted; this is the best I can do right now without re-reading from a textbook or checking a reference book.
| Nov5-08, 03:17 AM | #4 |
IUPAC naming rules
Eh, the above poster is a little off. IUPAC dictates you start at the closest carbon to the substituants. Cl in this case, so all you do is number the chlorines making sure that Cl is at carbon one, and (it doesn't apply in this situation) that any other substitutants would be in their lowest number.
the answer is 1,4-dichlorobenzene a little more advanced - since this is a hexyl compound, you could name it ortho-dichlorobenzene because the first chloride dictates carbon 1, and the other is in the ortho (opposite) position. If it was adjacent (1,2) it would be para-, and if it was in between opposite and adjacent (1,3), it would be meta-. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: IUPAC naming rules
| interactive file naming for naming multiple files in fortran90 | Programming & Comp Sci | 2 | ||
| Why is oxalic acid called ethane-dioic acid | Biology, Chemistry & Other Homework | 1 | ||
| IUPAC naming!!! | Biology, Chemistry & Other Homework | 5 | ||
| circle geometry- bisector rules vs. perpendicular rules | General Math | 1 | ||
| IUPAC names | Chemistry | 17 | ||
