Question about the output of a car battery in amps
The discussion revolves around the appropriate amperage output required for a 12v car battery to effectively power an electric anchor winch. Participants explore the specifications needed for the winch to operate smoothly, as well as alternative options for powering the winch.
  • One participant notes that the winch may require a higher amperage than the 3 amps provided by the initial inverter, suggesting that this low output causes slow and jerky operation.
  • Another participant mentions that medium winches typically run around 15 amps, although they express uncertainty about this figure.
  • The original poster later confirms that a 15 amp inverter works well with the winch, indicating that they have found an appropriate power source.
  • One participant suggests considering a 120v winch as a simpler and potentially cheaper alternative, implying a preference for different power solutions.
Participants generally agree that a higher amperage is necessary for the winch to function properly, with a specific mention of 15 amps as a suitable level. However, there is a disagreement regarding the necessity of the inverter versus alternative solutions like a 120v winch.
The discussion lacks specific details about the winch's power requirements, as the original poster could not find any labels or specifications. This absence of information may affect the reliability of the claims made.
Individuals interested in using electric winches, those exploring power inverter options, or anyone seeking to understand the amperage requirements for similar applications may find this discussion relevant.
wizer
Hi. I joined to ask this one question..but who knows maybe I will stick around and learn other things..lol...
I bought an electric 12v anchor winch which is designed to be used with a 12v car battery on a boat. I intend to use it to hoist my bicycles to the ceiling of my garage. However, the AC to DC power inverter that I tried, which outputs 3 amps...makes the winch run very slowly and with a jerking motion. I assume this is because the amperage is way low. So I need a power inverter with a higher amperage rating...
My question..how high?
Welcome to PF, Wizer.
The requirements should be listed on the label, or at least in the owner's manual. I believe that most medium winches run about 15 amps, but I'm not sure.
Thanks Danger..
No label anywhere on the winch or on the manual...I know, there should be, right?
I ran over to RadioShack, and picked up a 15 amp AC to 12v DC power inverter and it appears to work perfectly.
So you are correct, and that confirms that I am in the right power range for that winch.
Thanks.
You're quit welcome.
Next time buy a 120v winch...cheaper, simpler and just plug it into any wall outlet...
  • · Replies 16 ·
  • · Replies 23 ·
18K
