How do we know the maximum speed of light?
The speed of light in a vacuum is a theoretical abstraction influenced by various physical principles, including the non-zero permeability and permittivity of free space as described by Maxwell's equations. The discussion highlights that observable effects, such as the Casimir effect and Lamb shift, indicate that the vacuum is not devoid of properties that affect light's speed. Additionally, gravitational fields can refract light, further complicating the measurement of its speed in a true vacuum. Understanding these limitations is crucial for accurately interpreting experimental results related to the speed of light.
  • Maxwell's equations
  • Mass-Energy Equivalence
  • Strong Equivalence Principle
  • Quantum effects such as the Casimir effect and Lamb shift
  • Research the implications of Maxwell's equations on light propagation
  • Explore the Casimir effect and its relevance to vacuum properties
  • Investigate the Lamb shift and its impact on light speed measurements
  • Study gravitational lensing and its effects on light behavior in varying gravitational fields
Physicists, researchers in quantum mechanics, and anyone interested in the fundamental principles of light propagation and the nature of vacuum in physics.
theshadow27@gmail.com
How do we know the speed of light in a vacuum if we've never been able
to measure it? Please correct me if I'm mistaken.
1) All observable space is saturated with CMBR, i.e. electromagnetic
radiation, which is a form of energy.
2) As asserted by the Mass-Energy Equivalence and the Strong
Equivalence Principle energy and mass produce a gravitational field in
the same way.
3) Light must obey the laws of space-time like all other things, as
such it is affected by gravity. Light travailing over locally-
irregular gravitational fields is refracted, e.g. a gravitational
lens, etc.
Thus we cannot observe the behavior of light in a "vacuum" devoid of
both mass and energy, as would be the case on the fringe of an
expanding. Or did I miss something?
JSD[[Mod. note -- If you work out the likely magnitude of these effects,
they're *very* tiny. Any experiment has some level of experimental
error, and if effects like (1), (2), and (3) above are well below that
level, then it's ok to neglect them. More generally, the "speed of
light in a vacuum" is an *abstraction*; any actual experimental
realisation is going to have experimental limitations and approximations.
What's important is that we understand and can quantify these limitations
and approximations.
-- jt]]
Science news on Phys.org
> the same way.
> lens, etc.
> JSD
> and approximations.
> -- jt]][/color]
1) Lightspeed is finite *precisely* because there is stuff in the
vacuum: non-zero permeablity and permitivity of free space; Maxwell's
equations, Lorentz invariance. The stuff that isn't there is
measurable as the Casimir effect, Lamb shift (try U(91+) rather than
H(+)), Rabi vacuum oscillations, electron anomalous g-factor...
1) Do you want a faster lightspeed?
http://www.npl.washington.edu/AV/altvw43.html
Scharnhorst effect
http://arXiv.org/abs/gr-qc/0107091
http://arXiv.org/abs/quant-ph/0010055
Phys. Lett. B236 354 (1990)
Phys. Lett. B250 133 (1990)
J Phys A26 2037 (1993)
2) http://arXiv.org/abs/0706.2031
Pookie pookie.
Uncle Al
http://www.mazepath.com/uncleal/
(Toxic URL! Unsafe for children and most mammals)
http://www.mazepath.com/uncleal/lajos.htm#a2
  • · Replies 42 ·
  • · Replies 26 ·
  • · Replies 18 ·
  • · Replies 45 ·
  • · Replies 45 ·
  • · Replies 29 ·
