Finding a bound for a Fourier coefficient
The discussion focuses on proving that the Fourier coefficient \( A_k \) satisfies the inequality \( |A_k| \leq Mk^{-4} \) given the function \( \phi(x) \) is continuous and differentiable up to the fourth derivative on the interval \([0,L]\). The integral representation of \( A_k \) is provided, and the Weierstrass M-test is suggested as a method to establish the bound. The key conclusion is that the fourth derivative of \( \phi \) is continuous, allowing the integral to be bounded by a constant independent of \( k \), leading to the desired inequality.
  • Understanding of Fourier coefficients and their properties
  • Knowledge of the Weierstrass M-test for uniform convergence
  • Familiarity with calculus, particularly differentiation and integration
  • Concept of continuity and differentiability of functions
  • Study the Weierstrass M-test in detail to understand its application in bounding series
  • Explore properties of Fourier series, particularly convergence and coefficient behavior
  • Review the implications of differentiability on the behavior of functions in Fourier analysis
  • Investigate the relationship between the derivatives of functions and their Fourier coefficients
Mathematicians, students of analysis, and anyone studying Fourier series and their convergence properties will benefit from this discussion.
Somefantastik
show that Ak will satisfy:
[tex]\left| A_{k} \right| \leq Mk^{-4}[/tex]
[tex]A_{k} = \frac{2}{L}\int^{L}_{0} \phi(x) sin \left( \frac{k \pi x}{L} \right) dx[/tex]
given
[tex]\phi(x) \in C^{4} ([0,L]) \and\ \phi^{(p)}(0) = \phi^{(p)}(L) = 0, p = 0, 1, 2, 3[/tex]
in this notation, \phi is continuous and differentiable up to 4th derivative over [0,L], and (p) denotes the order of the derivative.
I differentiated 4 times using substitution, and came up with
[tex]\frac{L^{4}}{k^{4}\pi^{4}} \int^{L}_{0} \phi^{(4)}(x)sin \left( \frac{k \pi x}{L}\right) dx[/tex].
I was told using the Weierstrass M-test (or Comparison test?) would help find solution, but I'm not sure how to proceed.
Any comments or suggestions?
You would use this result to apply the Weierstrass M-test, but I don't see how the M-test would give the inequality to you.
On the other hand, you're nearly there. The fourth derivative of phi is continuous, and sin(k*pi*x/L) is bounded by one, so you can bound the integral above by a constant that doesn't depend on k.
[tex]\frac{L^{4}}{k^{4}\pi^{4}} \left| \int^{L}_{0} \phi^{(4)}(x)sin \left(\frac{k \pi x}{L} \right) dx \right| \leq M[/tex]
I'm still not getting the inequality. Can someone please help me further?
  • · Replies 16 ·
