Thevenin's equivalent circuit problem
  • Thread starter Thread starter backstance
    Circuit Equivalent
The discussion revolves around applying Thevenin's theorem to determine the current in a 3-ohm resistor that is part of a parallel branch in a given circuit. Participants are exploring the feasibility of using Thevenin's equivalent circuit in this context.
  • Exploratory, Assumption checking
  • The original poster expresses doubt about the applicability of Thevenin's theorem, suggesting that it typically results in a series configuration which may not be suitable for finding currents in parallel components. They question whether a solution exists using Thevenin's approach or if Norton's equivalent would be more appropriate.
The conversation is ongoing, with participants sharing their thoughts and seeking clarification. Some guidance has been offered through external resources, but there is no explicit consensus on the best approach to take.
Participants are working with a specific circuit diagram linked in the thread, which may influence their reasoning and assumptions about the application of Thevenin's theorem.
backstance
use thevenin's theorem to find the current in the 3 ohm, parallel branch, resistor
http://img217.imageshack.us/img217/909/img0267cc7.jpg
Thevenin equivalent circuit, voltage divider rule
I don't think its possible, since thevenin's theorem ends up with a voltage source and a resistor in series, you can only find currents and voltages in components that are in series. In this circuit there is nowhere to make the cut and split the circuit across terminals A and B. Normally you'd need Norton's equivalent circuit to find the current in the 3ohm resistor. Am I right, or is there actually a solution using thevenin's?
Could anyone solve this problem?
any ideas? any help would be appreciated, thanks!
http://www.allaboutcircuits.com/vol_1/chpt_10/8.html
try and study it from the url. The circuit is quite the same as yours.
thanks for that, useful!
ur most welcome! :D
