Proving the Integral for n>1: A Scientific Approach
  • Thread starter Thread starter Daggy
    Integral
The discussion revolves around proving the integral for n > 1, specifically the expression \(\int\limits_{0}^{\infty}{\frac{1}{(x + \sqrt{x^2 + 1})^n}} \mathrm{d}x = \frac{n}{n^2 - 1}\). Participants explore various substitution methods and transformations related to hyperbolic functions.
  • Some participants attempt substitution with hyperbolic functions, specifically using \(x = \cosh(\theta)\) and \(x = \sinh(\theta)\). Others express uncertainty about the correctness of their substitutions and the implications of the limits of integration.
The discussion is active, with participants providing feedback on each other's attempts and questioning the validity of certain substitutions. There is a mix of suggestions and clarifications regarding the approach to the integral, but no consensus has been reached on a definitive method.
Participants note the importance of the condition \(n > 1\) and discuss potential issues with the limits of integration when using specific substitutions. There is also mention of missing factors and the need for careful handling of exponential terms during integration.
Daggy
Prove that for n> 1
[tex] \int\limits_{0}^{\infty}{\frac{1}{(x + \sqrt{x^2 + 1})^n}} \mathrm{d}x = \frac{n}{n^2 - 1} [/tex]
Tried substitute x = cosh theta, then
[tex] \frac{\mathrm{dx}}{\mathrm{d}\theta} = \sinh \theta[/tex]
[tex] \int\limits_{0}^{\infty}{\frac{1}{(x + \sqrt{x^2 + 1})^n}} \mathrm{d}x = \int\limits_{0}^{\infty}{\frac{\sinh{\theta}}{(\cosh{\theta} + \sinh{\theta})^n }[/tex]
I'm getting in the right direction here? I'm really stuck..
Daggy said:
Prove that
Isn't something missing here?
n > 1
I think he meant your attempt at a solution :wink:
well I believe that mentioning n > 1 also is quite important... I've tried to use sinh-substitution, but can't really say I'm getting any wiser about it.
Use cosh(x)=(e^x+e^(-x))/2 and sinh(x)=(e^x-e^(-x))/2. Now try to integrate it. It's really pretty easy.
[tex] <br /> \int\limits_{0}^{\infty}{\frac{1}{(x + \sqrt{x^2 + 1})^n}} \mathrm{d}x = \int\limits_{x = 0}^{x = \infty}{\frac{\sinh{\theta}}{(\cosh{\theta} + \sinh{\theta})^n } \mathrm{d}\theta<br /> [/tex]
[tex] = \int\limits_{x = 0}^{x = \infty} \frac{e^{\theta} - e^{-\theta}}{(e^\theta)^n} \mathrm{d}\theta[/tex]
Don't know what to do here.
Split it into two integrals. Use rules of exponents. And you are missing a factor of 1/2, I think.
[tex] \frac{1}{2} \int\limits_{x = 0}^{x = \infty} {e^{\theta - n\theta}} \mathrm{d}\theta - <br /> \frac{1}{2} \int\limits_{x = 0}^{x = \infty}{e^{-\theta - n\theta} \mathrm{d}\theta =[/tex]
Then integrating and substitute back, don't really seem to get rid of those exponentials..
Just continue. Write down the antiderivatives. n>1. The contribution from infinity vanishes. It's the theta=0 part that counts. And e^0=1. See, no exponential?
Your original substitution x= cosh(theta) has a fundamental problem: the lower limit of integration is x= 0 and cosh(theta) is never 0. I would suggest x= tan(y) instead.
Is that a problem? when integrating and substituting back the cosh dissappears doesn't it?
Yeah, it's a problem. If you use x=cosh(theta), 1+cosh(theta)^2 isn't equal to sinh(theta)^2. It's the other way around. Use x=sinh(theta). (You had said you were using sinh-substitution, and I didn't notice you had it backwards.) It looks almost the same as x=cosh(theta) except for a sign difference.
So
[tex] \int\limits_{0}^{\intfty}{\frac{\cosh{\theta}}{(\sinh{\theta} + \cosh{\theta})^n}}\mathrm{d}\theta = \frac{1}{2}\int\limits_{x = 0}^{x = \infty}{\frac{e^{x} + e^{-x}}{(e^x)^n}}{\mathrm{d}\theta}[/tex]
and
[tex] \frac{1}{2}\int\limits_{x = 0}^{x = \infty}{e^{\theta - n\theta}}\mathrm{d}\theta + \frac{1}{2}\int\limits_{x = 0}^{x = \infty}{e^{-\theta - n\theta}}\mathrm{d}\theta <br /> [/tex]
and then factorize e^{1 - n} out?
[tex] \frac{e^{1 - n}}{2} \int\limits_{x = 0}^{x = \infty}{cosh \theta}~ \mathrm{d}\theta[/tex]
Noooo. And you can change your limits to theta=0 etc, ok? Your first integral is e^((1-n)*theta). That's EASY to integrate.
ahh. figured out, thanks
  • · Replies 105 ·
13K
  • · Replies 18 ·
