What Frequency is Needed for Effective Ultrasonic Cleaning?
  • Thread starter Thread starter ghad58@yahoo.
    Wavelengths
The discussion focuses on determining the minimum frequency required for effective ultrasonic cleaning of particles approximately 3.0 X 10-2 cm in diameter in an aqueous bath. The speed of sound in water is established at 1500 m/s, leading to a calculated frequency of 5 x 106 Hz. Participants emphasize the importance of using SI units consistently to avoid conversion errors, particularly when dealing with non-dimensionless results.
  • Understanding of ultrasonic cleaning principles
  • Knowledge of sound wave propagation in liquids
  • Familiarity with SI units and their conversions
  • Basic mathematical skills for frequency and wavelength calculations
  • Research the effects of different ultrasonic frequencies on cleaning efficiency
  • Learn about the relationship between particle size and ultrasonic frequency
  • Explore various ultrasonic cleaning equipment specifications
  • Investigate common mistakes in unit conversions in scientific calculations
Engineers, technicians, and researchers involved in ultrasonic cleaning applications, as well as students studying acoustics and fluid dynamics.
ghad58@yahoo.
Particles approximately 3.0 X 10-2 cm in diameter are to be scrubbed loose from machine parts in an aqueous ultrasonic cleaning bath. Above what frequency should the bath be operated to produce wavelengths of this size and smaller?
speed of sound in water = 1500 m/s
frequency = (speed of sound)/wavelength
1500x10^4/3 = 5x10^6 Hz
does this sound right?
Hi
Yes, your calculations seem correct. But let me give you a tip, always do your calculations in SI units. You have the velocity in SI unit, why not change the diameter to SI instead of the other way around?
In this case you are alright since frequency is dimensionless. However, in a case where the result is not dimensionless you will save time and minimized conversion errors risks having used SI units to begin with.
Cheers!
9K
