Synchronous Motors: Can Rotor Spin with 3-Phase AC Supply?
The discussion centers on the operation of synchronous motors, specifically the feasibility of replacing the DC field winding with a low-impedance short-circuited coil while supplying the stator with 3-phase AC. Participants explore whether this configuration would allow the rotor to spin, follow the direction of the rotating magnetic field (RMF), and maintain synchronous speed.
  • One participant questions if the rotor would spin under the proposed conditions and whether it would follow the RMF direction and speed, seeking insights on the mechanics involved.
  • Another participant suggests that Lenz's Law may impede the rotor's motion, particularly at higher frequencies, noting that the induced current in the coil could create opposing fields that complicate the rotor's behavior.
  • A different participant describes a related concept known as a repulsion-induction motor, explaining its operation and historical context, indicating that it starts as a universal motor and transitions to synchronous operation.
  • One participant confirms that the described method is a form of induction starting for synchronous motors, mentioning practical considerations such as the addition of a resistor to improve starting torque.
Participants express differing views on the mechanics of the proposed motor configuration and its operational viability. There is no consensus on whether the rotor would successfully spin or maintain synchronous speed under the outlined conditions.
Participants acknowledge various assumptions regarding the behavior of the coil and the effects of Lenz's Law, but these assumptions remain unresolved. The discussion also touches on historical motor types and practical modifications for improved performance.
Individuals interested in electrical engineering, motor design, and the principles of synchronous and induction motors may find this discussion relevant.
mrk2k5
Hi, I have a question about synchronous motors. If the DC field winding of a synchronous motor were to be replaced by a low-impedance short-circuited coil and the stator were to be supplied with 3-phase AC, would the rotor spin?
If the answer is yes, would the rotor follow the direction of that of the RMF and would the rotor speed be the same as that of the RMF, like in a synchronous machine?
Any explanations and insight would be much appreciated.
Thanks!
I do have the feeling Lenz Law is working against you, but I am not sure, especially at higher frequencies. So the current induced in the coil will try to prevent the field from changing. If the field drops on a stators shoe, the coil will produce a field in the same direction and thus be attracted to the stator. When the field rises the coil will produce an opposing field, which would turn the coil away, but this causes a drop in the coils field again which might pull it back. Maybe you could you make the coil a LC-Oscillator. But all of this is speculative
What you are describing is called a repulsion-induction motor. A repulsion-inductor motor starts as a universal motor with the field and armature wired in series (I think). After it is up to speed the brushes are short circuited and it run as a synchronous motor locked to the line frequency. I don't think this type of motor has been manufactured for quite a long time. It boasted large starting torque with regulated speed. It is technically a repulsion-start/induction-run motor.
Yes, indeed this way is one of ways for running of synchronizing motor which called induction starting. Of course low impedance induction path is not suitable for good starting and in practice one resistor adds to induction path for improving of starting torque.
For more information you can refer to Machine Riddle No.12 from http://electrical-riddles.com
:smile:
