How to Linearize and Fit Data Points in MATLAB?
This discussion focuses on linearizing and fitting data points in MATLAB using two specific functions: an exponential function, f(x)=CeAx, and a hyperbolic function, f(x)=1/(Ax+B). The participants discuss the transformation of variables, specifically using Y=ln(y) for the exponential function and Y=1/y for the hyperbolic function, to facilitate linear regression. The provided MATLAB code for polynomial fitting is noted, but participants express confusion regarding its application to the specific problem set.
  • Understanding of least-squares curve fitting
  • Familiarity with MATLAB programming
  • Knowledge of logarithmic transformations
  • Basic concepts of polynomial regression
  • Implement MATLAB code for linearizing data using Y=ln(y) for the exponential model
  • Develop MATLAB code for linearizing data using Y=1/y for the hyperbolic model
  • Compare the goodness of fit for both models using MATLAB's fit functions
  • Explore MATLAB's curve fitting toolbox for advanced fitting techniques
Students and researchers in mathematics, data analysis, or engineering who are working on curve fitting and data modeling in MATLAB.
hunter55
For the given set of data, find the least-square curve:
A) f(x)=Ce^Ax, by using the change of variable X=x, Y=ln(y), and C=e^B to linearize the data points.
B) f(x) = 1/(Ax+B), by using the change of variable X=x and Y = 1/y to linearize the data points.
x : [ -1 0 1 2 3]
y : [ 6.62 3.94 2.17 1.35 0.89]
I need the MATLAB code on how to do these 2 problems I am confused and which curve gives a better fit. ??
This is the only code i know but idk how to do it with the question they are asking i need to pertain it to that
function C = poly(X,Y,M)
n=length(X);
B=zeros(1:M+1);
F=zeros(n,M+1);
for k=1:M+1
F(:,k)=X'.^(k-1);
end
A=F'*F;
B=F'*Y';
C=A\B;
C=flipud(C);
These are the coefficients:
-0.0458x^3
0.5225x^2
-2.1567x
3.9040
I am confused with what the question is asking i know I am suppose to have a ans for part A and B
Think about what a change of variable is, then figure out how to apply that to the data.
Aka, when you make a substitution for y=ln(y), that just means you take your y list, and just take the ln of that. That now because the new measurement for what used to be the y-axis.
Does that make sense?
