Ecliptic Longitude and Right Ascension of the Sun
The discussion revolves around the relationship between ecliptic longitude and right ascension of the Sun, specifically focusing on when their maximum difference occurs, the corresponding declination, and the calendar dates of these events. The conversation includes mathematical reasoning and exploration of celestial mechanics.
  • One participant questions the maximum difference between ecliptic longitude and right ascension, suggesting that this observation is unique and lacks a name.
  • Another participant points out that ecliptic longitude and right ascension are measured on different great circles, complicating the relationship due to the Sun's non-uniform motion caused by orbital eccentricity.
  • A mathematical relationship is proposed involving the tangent of right ascension and ecliptic longitude, hinting at periodic maxima throughout the year.
  • Further equations are presented to relate declination, right ascension, and ecliptic longitude, with some participants expressing uncertainty about the next steps in solving these equations.
  • One participant expresses skepticism about the complexity of the proposed equations and suggests that the relationship between the coordinates is more straightforward than presented.
  • Another participant introduces the concept of the "Equation of Time," emphasizing its relevance to understanding the differences between solar time and mean time.
  • Discussion includes calculations and numerical examples, with one participant providing a specific date and angular difference, while another challenges the accuracy of that date.
Participants express differing views on the relevance and complexity of the mathematical relationships involved. There is no consensus on the maximum difference between ecliptic longitude and right ascension or the specific dates these occur.
Participants mention various mathematical approaches and equations, but there are unresolved steps and assumptions in the calculations. The discussion reflects a mix of exploratory reasoning and technical challenges without a clear resolution.
Helios
Here's a question. Where do the ecliptic longitude and the right ascension ( of the Sun )reach their maximum difference? What is the declination for these events? What calendar dates do you suppose this happens? I know the answer. I've never heard anyone make this observation except me. These events don't even have a name?! We can even name them here and now for the first time!
Astronomy news on Phys.org
What are you saying? Ecliptic longitude is measured on one great circle, and right ascension on another one. The sun travels the ecliptic in non-uniform way strictly speaking due to eccentricity of the orbit. Let's say its about a degree a day. Then, sun's coordinate point on the equator also travels like a shadowy projection. If obliquity was really big, the speed on the equator of that point (defined by intersection of great circle containing north celestial pole P and the sun) travels a little quicker starting from gamma point, then slower, then quicker and there I give up. What is the difference between the two?
OK, here's a hint. The relationship between the two is
[tex]tan \alpha = tan \lambda cos \epsilon[/tex]
Right Ascension ( alpha )
Ecliptic Longitude ( lambda )
Obilquity Angle ( epsilon ) = 23.439°
Find where [tex]\lambda - \alpha[/tex] reaches the maximum ( 4 times per year ).
I wrote all equations for triangle declination-ascension-longitude but I don't know what to do next.
sin(alpha)=cos(e)sin(lambda)
Right? Lambda is changing at constant rate (pretend), alpha is whatever.
That's not it.
write
[tex]f = \lambda - \alpha = \lambda - arctan( tan\lambda cos\epsilon)[/tex]
then find [tex]df/d\lambda[/tex]
set this to zero to find maximum
then values for [tex]\lambda[/tex]
and [tex]\alpha[/tex] will follow.
Helios said:
That's not it.
write
I haven't reverse engineered your equation, normally I'd trust it but it seems more complicated than necessary. I used program "Derive" to solve the first differential as an equation but all solutions seem to be complex! It appears absurdly complicated.
Clearly, equator and ecliptic are two great circles on same sphere at an angle. Great circle ecliptic_poles-sun is rotating and so is celestial_poles-sun circle which is tracing sun on equator and recording declination. All 3 coordinates are one-on-one and one on date of tropical year (short term). Hence let's see the tables with numbers...
...and I get
for l=0 to 360
RA=acos[cos(l) / asin( sin(e)sin(l) )]
May 31st 2009, angular difference worth almost 2.5 degrees. How about that?
Well, the month is right, but you're still cold
I protest! First its irrelevant thing to know. Second I didn't design these awful arc sine functions.
Irrelevant? It's not irrelevant. Know that there's an "Equation of Time" that corrects sundial time to local mean time. The Sun runs fast or slow compared the mean time. Should we correct for obliquity, we must know
[tex]\lambda- \alpha[/tex]
The fact that it has extrema should be interesting to any calculus student. Oh well.
So there's another feature of these same points!
Firstly, Ecliptic Slope (sigma) is related to declination by
[tex]cos\epsilon = cos d cos\sigma[/tex]
Find where the declination equals the ecliptic slope or the negative of the ecliptic slope.
Then use
[tex]sin d = sin \lambda sin \epsilon[/tex]
This approach is too easy, a dead give-away to the problem.
  • · Replies 16 ·
16K
  • · Replies 142 ·
142K
22K
