How Would Melting Polar Ice Caps Affect Earth's Day Length?
The discussion centers on calculating the effect of a 10-meter rise in sea level due to melting polar ice caps on Earth's day length. Participants emphasize the importance of the moment of inertia, specifically using the formula for a sphere, 2/5 MR², to determine changes in inertia as water spreads uniformly across Earth's surface. The current moment of inertia of Earth is noted as 8.1 x 1037 kg m². The conversation highlights the need to consider angular momentum conservation to derive the impact on Earth's rotation speed.
  • Understanding of moment of inertia and its calculation for spherical objects
  • Basic knowledge of angular momentum conservation principles
  • Familiarity with the concept of uniform mass distribution over a surface
  • Ability to perform algebraic manipulations with physical formulas
  • Research the implications of angular momentum conservation on planetary rotation
  • Study the effects of mass distribution changes on Earth's moment of inertia
  • Explore the relationship between sea level rise and Earth's rotational dynamics
  • Learn about the physical properties of water and its impact on Earth's surface area calculations
Students in physics, environmental scientists studying climate change impacts, and researchers interested in geophysical dynamics related to Earth's rotation.
zoner7
If the melting of the polar ice caps were to raise the water level on the Earth by 10m, by how much would the say be lengthened? Assume the moment of inertia of the ice in the polar ices caps in negligible (they are very near the axis), and assume that the extra water spreads out uniformly over the entire surface of the Earth (that is, neglect the area of the continents compared with the area of the oceans). The moment of inertia of the Earth(now) is 8.1 X 10&37 kg m^2.
good luck... I have no idea how to even go about doing this. I know that i need to examine the radius increase of the Earth do to the water level changing, but since I can't look up any values that aren't given to me, I really have no idea where to even start. if anyone has even the slightest inkling of what to do, I'd love to hear it.
thank you in advance
hmm I suppose that the moment of intertia of a sphere is key:
2/5 MR^2
We can set 2/5 MR^2 = x.
we know that this increases to 2/5 M(R + 10m)^2.
Then the change in the moment of inertia would be equal to [2/5 M(R + 10m)^2 - x], or 8.1 X 10&37 kg m^2 - x.
That's one step down :)
2/5 MR^2
I'd have to wonder if a more useful approach wouldn't be to calculate the moment of a 10 m hollow sphere of water at the radius of the earth. (Calculate the surface area of Earth times 10 m times mass of water to get the mass.) Then add that to the known moment of the Earth to arrive at the total moment.
Because the mass of the water won't be as much as the weight of the magma based densities of the landmass.
Since angular momentum needs to be conserved ... you can get to the change in rotation.
I still could not reach the answer, please can you explain more?
18K
  • · Replies 78 ·
11K
